Question about Dryers
Dryer turns on and fires but it takes forever .exhaust is not plugged.sometimes igniter glows but flame doesnt light Estate by Whirlpool
    Scholar:
  • 44 Answers
First, are you sure the vent is not clogged? Maybe AT the dryer or just inside? I ask only because that's what it sounds like and is much easier thatn the other options.
Second, assuming the vent is crystal clear, it will more than likely be lint/dust clogging up the burner or perhaps the orifice and diverting the gas away from the igniter. This should be accessible through an access panel at the front if you're lucky, at the back if you're not. Just vacuum it thouroughly and carefully and you should be good to go.
P.S. If you're going to double check the vent/exhaust anyways, why not stick the vacuum inside the dryer at that point, can't hurt, might help.
P.P.S. Though this should be obvious: Turn the gas off before servicing, unplug the power and be gentle.
Posted on Sep 09, 2009
  • 864 Answers
If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Whirlpool dryer will not ignite.JET FLAME WILL NOT GO ON.
if the ignitor is lighting up, or if you have a actual flame pilot light, depending on the machine, if you have a pilot light, check the thermocouple that the flame from the pilot is supposed to heat , but thats on very very old machines , if you have a glow plug , ( a heat source that comes on electrically and glows , then you need to check the 2 coils that are on the gas valve, they have gone bad
Jul 13, 2011 | Whirlpool Dryers
I have a a Whirlpool LGB6000KQ1 Gas Dryer. Sometimes the heat comes on, sometimes it does not. Could it be the thermostat or something else?
it appears as if your unit has a small plastic plug/access hole cover below the left corner of the dryer door. if you remove that you should be able to look within the dryers burner area and observe what might be happening..
if when you turn the dryer to a normal timed cycle, on high heat and start the unit, shortly after the dryer begins running you should be able to observe the glow ignitor glowing through that access hole, and shortly after that hear a click and flames appear, if is not glowing then there are probably thermal fuses blown out on the backside of your unit, or the ignitor is bad.
if however it does glow, and maybe even fire up once then all the safetys mentioned b4 are good.. now sit there and watch your ignitor/burner assembly.. the flame will cycle on and off depending on the dryers internal temperatures, but the main thing to look for is whether the ignitor glows, then fails to click then produce flames, if that be the case the gas valve coils are bad and need to be replaced part # is 279834 - M STYLE COIL KIT
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LGB6000KQ Gas Dryer
The flame gose on and off it takes 2hr to dry
if the flame only lights once or twice when you first start your dryer, then afterwards the ignitor just glows yet the gas valve does not open producing fire the gas valve coils are defective.
however if the flame goes on and off all during the cycle as it is designed to and your only complaint is the length of time necessary and not that they do not heat i would suggest thoroughly cleaning out your vent line from where it exits the house back to the dryer. correct any crushing of the junk flexible hose by running rigid proper aluminum ducting and elbows to ensure adequate air flow through the exhaust duct.
best of luck,
ttfn
Oct 24, 2009 | Estate Dryers
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer , Flame cycles on and off a few times then ignigter glows but flame does not light
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 16, 2009 | Whirlpool LER4634J Electric Dryer
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Jun 28, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Gas Dryer
Yes, that is most likely the problem. Once the glow bar igniter glows so hot, the switch opens & drops power to the igniter.(The radiant sensor has continuity while cold & open when a flame is present.) At the same time, by opening it redirects power to the valve coils allowing them to open & gas flow to the burner assembly. The dying glow of the igniter fires the gas. However, if your igniter glows, the radiant sensor is good. In this case, you'd need to replace the gas valve solenoids.
Aug 01, 2007 | Whirlpool LGR5644J Gas Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
