Question about JVC KD-G140 Car CD Player
My radio will not work
I have a jvc kd-g140 radio and when i plug it in it will automaticaly turn on and everything is lit up and you when you press a button nothing happens
    President:
  • 196 Answers
For turn off this radio press power botton for 3 second. if you press only with one touch is for mute. turn on press one secon---turn off press 3 second---1 touch is mute.
Posted on Apr 28, 2010
Need instructions on how to wire a jvc kd-g140 radio
http://resources.jvc.com/Resources/00/01/13/GET0485-001A.pdf
install instructions for your radio is on page 4
Jun 07, 2010 | JVC KD-G140 Car CD Player
How do i set clock on jvc kdg140
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob/button, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
May 11, 2010 | JVC KD-G140 Car CD Player
CAN I HOOK UP MY CELL PHONE TO THE RADIO? JVC
unfortunately this model dosnt come with bluetooth capability, you can only plug in your mps/ipod etc.
Mar 17, 2010 | JVC KD-G140 Car CD Player
Bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
Sep 11, 2009 | JVC KD-G140 Car CD Player
JVC KD-G140 Chevy s10 problem
Your headunit is getting constant power (yellow wire). You most likely have no switched power (acc red wire). You can be certain by testing the red wire w/ a 12 volt test light when your ignition is on. If there is no power to this wire then you probably have a blown fuse. The radio fuse should be a 10amp fuse located in the drivers kick panel.
May 28, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Set clock on radio
Hello atesha23,
Below is the step-by-step procedure for setting the JVC clock. Please note that after you have entered the PSM mode, if you have not pressed a button for about 2 seconds, the radio will automatically exit the mode and return to normal operating mode. In that case, you must restart PSM by holding the "SEL" button until the display changes.
(1). Enter the PSM mode by pressing and holding the
SEL button until the display changes.
(2). Use the rocker switch left/right until "CLOCK
H" is displayed.
(3) Set the clock hours by turning the volume
control up/down.
(4) Press the rocker switch again until "CLOCK M"
is displayed.
(5) Set the clock minutes by turning the volume
control up/down.
(6) Press the SEL button to finish and EXIT.
Hope this helps.
Mar 31, 2009 | JVC KD-G140 Car CD Player
Setting the time
PRESS THE 'SEL" BUTTON MORE THAN TWO SECONDS AND THEN WITH THE KNOB VOLUME CHANGE SET HOUR THEN PRESS THE FORWARD BUTTON TO SET THE MINUTES WITH THE KNOB VOLUME THEN PRESS SOURCE.
Mar 18, 2009 | JVC KD-G140 Car CD Player
JVC KD-S15 setup - How do I turn "Demo" Off?
press and hold the sel button....select an itenm (useing the silver button beside the volume dial).....then use the volume dial to adjust ,time , demo alot of others...then press sel button to finish.....this is straight out of the instructions...hope it helps you
Dec 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
Don't know how to set the clock on my jvc kd-g240/kd-g140 car stereo
press and hold the sel button until the menu pops up then scroll through til you see clock settings.
Dec 20, 2008 | JVC KD-G140 Car CD Player
No able to play mp3s on Car CD DECK
unfortunately the jvc radio model # kd-g140 will not play mp3 on a cd disk- it will play a mp3 player thru the aux jack on the front of the head unit- please rate my help
May 19, 2008 | JVC 50W x 4 MOSFET CD Deck with MP3...
JVC KD-G140 Car CD Player Logo
289 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
