Question about Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater
Cuts out in 10 seconds
After pilot light has ignited flame it burns out in about 10 seconds
    Sergeant:
    Champion:
  • 232 Answers
You may want to replace the regulator
Posted on Sep 15, 2009
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
The pilot light ignites but goes out when the button is released, I have held it down for over a minute, can you help
The pilot light works with a safety cut out device should the flame ever get blown out. The device cuts the gas supply to stop accidents. If you look where the pilot light burns you will see a small metal looking tip in the flame, this is the device. It is full of liquid:that expands when the flame keeps it hot. The other end applies pressure on the cut out switch. The liquid within can fail. It is very easy to follow the tube to the cutout switch, unscrew the whole tube assembly and take to a hardware store for a cheap replqcement that you screw back in. Any excess tube carefully wind up in a coil, do not bend sharply as liquid will excape (liquid usually oil based) Once refitted ignite per instructions for your device. Happy fixing.
Sep 03, 2015 | AGA Kitchen Ranges
How do I find and light the pilot?
Linda, it is not easy to explain I would go to the Goodman website and see if you can down load a manual for your unit or maybe see a blown up picture of it showing the pilot
once you can see the parts and know where they are then we can help a little maybe
You have to find the gas valve on it is a knob that should have on off pilot you would turn that to pilot and push down hold for about 30 seconds
Before doing that you will see three tubes coming from the valve one big one and two smaller ones follow the bigger of the two small ones
At the very end of that is the pilot light (it will not be burning ) After holding the pilot knob down fro 30 sec place a flame/match near that opening at the end of the tube you followed a small flame should start ,this may take several attempts to light
If this is an electric type you would do the same thing only you should see a button that says push or igniter so you would hold the pilot button down and then push and release push and release igniter until the pilot lights once it comes on and burns for a few seconds release the pilot knob and turn the knob to on
You then should get a flame if the thermostat is set
If you have never done this see if you can get a neighbor or someone to show you how
Oct 17, 2013 | Goodman Heating & Cooling
New blue flame heater, everything is hooked up, gas is going to unit, I have a natural gas hookup, in the correct port, knob is turned and locked into the NG position but unit wont light. There is gas...
do you have the pilot light burning if not then you have to get in burning first
Put knob in pilot position push down and hold for at least 30 seconds or longer then if there is an igniter push and release it push and release till pilot light comes on .Continue to hold pilot light button down for another 10 seconds or so, release pilot button and turn button to on or up a number or set T stat
Main flame should come on and burn
Oct 13, 2013 | Procom Heating & Cooling
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a goodman propane furnace, model # GMPN080-4 that lights for about five seconds and then cuts off. It does this three times and then stops all together. Tried lightly sanding the flame sensor and it...
The goodman furnace will try and light three time before it faults out for safety reasons. Adjust the flame sensor so that it is closer to the flame or actually in the pilot flame. If the flame sensor is inside the pilot flame and still does not stay lit, your flame sensor is probably defective and should be replaced. You can get one at Ferguson's counter sales.
Dec 12, 2010 | Heating & Cooling
I replaced the ignition transformer in my Teledyne Laars epc325 pool heater and cleaned everything. When I switch the heater on the burners all work fine but they only cycle on for about 10 seconds then...
This is probally your ignition wire is bad and not reading flame at the pilot or your pilot is bent or something so that when the pilot lights the flame isn't hitting the sensor probe at the pilot. When looking under the heater use a mirror so if you get roll out of the flame you don't get burned. Good luck and be careful.
Feb 26, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Delayed ignition of a Ruud high efficiency upflow 90 plus propane
It sounds like the first thing to do is have burners and pilot cleaned and adjusted so ignitor and pilot flame is close to main burner ignition rail.
The "whoosh" is due to delayed ignition because the pilot flame does not come in contact with main gas.
One more thing that should be tested is the gas pressure and combustable air mixture to be sure it is correct.
It is always best to have a qualified technician do this for you, In many areas the gas supplier with check and safety test this for you.
Nov 24, 2009 | Ruud UBHC Air Conditioner
20,000btu ventfree natural gas heater ,,,,,pilot lights ....flame lights and burn well for about 30 seconds ...then there is a ''click'' in the control knob area and the flame and pilot go out ? Is the...
you have a thermo couple that is in or near the flame sounds like you have a faulty one. it detects the flame and keeps the gas flowing. if it does not then it cuts the gas supply. It is done for safety
Oct 31, 2009 | Heating & Cooling
Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater Logo
104 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
