Question about Garden
Pressure wahser has no pressure but it never froze help
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
You probably have a stuck valve. It really depends what type of pressure washer you have though. Some have a knob that you can turn to increase or decrease the pressure. If you have a knob like this the u-cup in this assembly may be damaged. Or the pin that is pushed down is stuck.
If you do not have a knob and the line comes straight from the pump, you may have some orings damaged in the valves.
Sometimes corrosion is the problem and has broken off and gotten stuck in the valves.
It is definitely in your pump though, if your motor still runs.
Posted on Sep 09, 2009
2005 Chevy Equinox left front brake caliper locks up
Your vehicle should have rear drum brakes...They have to be adjusted manually for correct adjustment...People say they self adjust but it is not good enough....by adjusting the rear it will decrease the pressure on the front and deliver equal braking...This will help eliminate caliper pressure overload....I'm not saying that is your caliper problem but it is insult to injury and will save the life of front brakes.....Now your caliper problem..FYI..A rule of thumb is anytime you change a caliper you should always replace both calipers to have identical braking pressure".The same with brake hoses and rear wheel cylinders.....The caliper that froze in the first place got hot and boiled the brake fluid and quite possibly partially collapsed the caliper brake line/hose inside as Clint and Frank stated....I am going to guess that the first caliper froze under normal conditions however got hot enough to internally damage the caliper line/hose...Then you may think of the pressure regulator being bad in which case could be a problem......So this is what you do".Since we know the left front caliper line/hose has been exposed to heat it needs to be replaced anyway...also the fluid was boiled and it needs to be changed / bled...The new caliper that froze should be ok unless it was bad off the shelf which is rare but possible."..Change the line/hose,bleed the brake system and let the mechanic test drive before you pay and leave..The mechanic will know before driving if the new caliper that froze is bad or not by rotating the wheel...This is the cheapest way...And you will know if the pressure regulator is bad or not just by bleeding system........I hope this helps....."Brooks/Metalpoet....."....
Jun 13, 2014 | 2005 Chevrolet Equinox
I need a owners manual for a pressure wahser GCV 160 from honda
MiTM will have that. See mitm.com Honda makes the motor but not the pressure washer. Honda does have manuals if you need one for that GCV160 motor.
Oct 20, 2012 | Mi T M Chore Master Pressure Washer - 5.5...
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Water is filling the tub when not in use
One of the water inlet solenoid valves is faulty -- it's not closting when the "water-fill" function is off. The solenoid valves are the parts the hoses on the back of the wahser are connected to. There are two -- hot and cold.
Cleaning them and replacing wahsers / O-rings / gaskets may solve the problem or may need to be replaced. More info, let me know.
Charlie
Feb 12, 2011 | Maytag Neptune Washer
I would like to know if this pressure wahser use only gas or (Gas and Oil) is mixed?
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
Oct 15, 2010 | Dewalt DPD3300 Commercial Pressure Washer
I am getting error code F35 on my Nattag serues 5000 wahser. How do I fix it?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2010 | Washing Machines
I bought a troybuilt pressure washer used and i changed the motor oil and ran it maybe 5 minutes. later i checked the oil level again and it shot out the cap and i noticed the pump oil level is also...
if you left it sit for a while & did not turn the fuel tap off,it may have flooded and therefore the oil level would have risen causing the oil to over flow.
always turn the fuel tap off when not using your pressure wahser.
Sep 06, 2010 | Honda Pressure Washer PSI 3000
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
