ERROR E7 TOSHIBA WASHER AW8960S
I HAVE AABOVE MENTIONED WASHING MACHINE. FOR LAST FEW DAYS IT RUNS ONLY 1 OR 2 MINUTES ADN THE ERROR E7 APPEARS AND MACHINE STOPS. PLS ADVISE WHAT SHOULD WE DO TO GET RID OF THIS PROBLEM. THANKS AND BEST REGARDS, TARIQ
Check the water level switching or door sensor
Posted on Nov 01, 2011
  • Ebraim Shajerati Aug 31, 2013
    excuse me i made amistake, it's E74
    New Friend:
  • 24 Answers
TOSHIBA electric washing machine AW-B700KSE. ERROR E2 appears and machine stops.pls advise what should we do to get rid of this problem?
Posted on Oct 11, 2013
    New Friend:
U have to replace main pub or programme ic
Posted on Nov 06, 2015
Toshiba washing machine When I push on the error E7-4 shows and then it turns off what is E7-4 error ?
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
Jul 31, 2016 | Washing Machines
My Aw9770SB toshiba washing machine kept showing this E7 -1 problem how can I fix
Hi Sunny the link below is a toshiba site which you'll find interesting, Please read and scroll down the whole page, I copy and pasted it part for you to read I hope this helps... CHEERS
((if an E6 or E7 error code is displayed on the control panel of your washer-dryer, there is a possibility of wiring disconnection. Please stop use it immediately, remove the plug from the socket and contact the help desk listed below.))
https://www.toshiba.co.jp/tha/info/140204_e.htm
Mar 22, 2016 | Washing Machines
Toshiba aw-1190s error code E7-4
MY WASHING MACHINE APPEARS ERROR 2 AND 3.PSE CONTACT 019-2450009 0R EMAILS EZALYIMTIYAZ@YAHOO.COM. ANY SUGGESTION PSE?
Nov 17, 2012 | Office Equipment & Supplies
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
Toshiba washing machine with error code e7-4
Toshiba top washer machine with error code e7-4. What the problem and how to solve.
Oct 08, 2011 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Please help us our washing machine is Toshiba AW8800S and theirs a error E5 what is that error means? please send to my email aflordeliza@hotmail.com
Please help us our washing machine is Toshiba AW8800S and theirs a error E7 what is that error means? please send to my email oceana.2000@yahoo.com
Oct 20, 2010 | Washing Machines
Error code f 21, what does this mean?
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
May 18, 2010 | Washing Machines
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
About toshiba washing machine
very simple you just press the WATER FLOW button, PRESET button and RINSE button to reset it memory test it out
Sep 13, 2007 | Washing Machines
Washing Machines Logo
2,189 people viewed this question
Top Washing Machines Experts
