Question about Garden
Engine dies my Toro would run for maybe 1/2 hr then stop now it is down to 2or3 min and stops.Walkbehind mower. 5 or 5.5 hp 3 yrs old
  • 718 Answers
Check and clean your gas tank. If still a problem there might be dirt in the carb.
Posted on Sep 26, 2009
Mower just stops after approx. 1 hr , will stert again straight away but backfires when it does , any ideas??
Riding mower? ... if so, it's your electric fuel solenoid located on the bottom of the carburetor
Oct 12, 2015 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
I have the 6.5 hp self propelled model, It starts fine and runs strong for aprox 5 min then dies, seems to die when it gets hot possibly, the die time is always the same aprox 5 min. Once it dies it will...
I don;t know what engine is on your mower but if it has the self contained electronic ignition coil I have seen happen on several engines. It would run good for several min. then the spark just stops . And it will not spark again until it sets and cools . Just make sure it is the ignition that is not working.
Sep 15, 2010 | Toro Lawn Mower With Toro Power Tools
Briggs stratton,16 H>P> runs smooth 'til mower is engaged.
Is the choke staying on perhaps? check spark and plug check airflow, get compression test maybe the oil/compression rings giving way... sounds like its getting hot and increasing fuel flow for some reason??? perhaps clean carb with some cleaner while running (remove air cleaner) spray directly into carby while running run at full throttle as you spray it will try and die ... relax on the spraying and see how it goes.. check air cleaner for blockages as the same time :) hope you get it working!
May 04, 2017 | Briggs & Stratton Briggs Stratton Vanguard...
Engine shutoff on hot days after 45 minutes.
it sounds like the electronic ignition system(under the flywheel) is going bad,that would cause the mower to shut down when it's hot. if you take it back to the repair shop ask them to replace it and it'll be good as new.. Good Luck
don't for get to give me a thumbs up
Apr 06, 2010 | Garden
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower does not strat
Did you possibly hit something? Sounds like the flywheel key may have sheared.
May 18, 2009 | Toro Lawn Mower With Toro Power Tools
Gas in the oil in my craftsman 17.5 riding mower
You have a bad antibackfire valve. It is located on carburator below the fuel bowl. You can replace it, or as I advise others, install an inline shutoff valve. Turn the fuel valve on to start it, then turn it off when you shut the engine down.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
