Question about Coffee Makers & Espresso Machines
Wont pump I took out the water tank to clean/refill and now it won't pump any water - I think it has an air blockage. How can I fix it?
  • otway_alanna Sep 09, 2009
    Tried that already.
    Thanks
  • 10,865 Answers
Remove the tank and fill it with fresh water then replace it.
Posted on Sep 09, 2009
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Refill water tank light won't go out
Then replace it because they are not repaired.
Jun 30, 2017 | Philips GC 8220 Iron
My shark vac and steam wont pump water to steam
Likely you have used tap water and there is now mineral deposits blocking the flow. I posted a video on how to take it apart to clean it.
www.youtube.com/watch?v=S4NglGXVv50
ALternatively, people have had success in putting CLR into the tank or Vinegar and pumping the unit and leaving it overnight in attempt to clear the blockage that way. I gave up and just took it apart and found a significant amount of mineral deposits blocking things up.
Jan 10, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My fish tank air pump broke and I think my fish aren't getting enought oxygen because of it. Should I buy a new one or can it be fixed?
Technically, it can befixed but if it happens once, it will likely happen again. You should buy a new one as they aregenerally pretty cheap. In the meantime,fill a large bowl with water and place the fish there. This will allow them to get some fresh oxygen. While the fish are in the temporary container,get rid of all of the water in the tank. Then, refill again with new, oxygenated water. I wouldn't leave them in this environment formore than a day before you purchase a new air pump.
May 13, 2012 | Fish
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
Once the dishwasher had finished the bottom was full of dirty water which won't drain away and now it wont work at all
More than likely a failed water pump, or blockage that has created a discharge problem. This could cause the circut breaker to trip. So, it is kinda messy, but if you drain the water by hand baling, clean or check the interior bottom d/w discharge intake & screen, reset the breaker, and restart. If the system still does not drain it's probably pump failure. I don't think people actual replace the pump, they just get a new d/w unit. Unless there is warranty coverage.
May 25, 2011 | Hotpoint Dishwashers
When adding air to a pressure water pump ,i
Sounds like the bladder is gone or inproper air pressure in water storage tank.
Bladder goes bad check it out with step 1
1-
One way to check for sure with everything hooked up. The air valve on top of the tank if pressed you will get water out of the valve which should be only air. This will let you know it should replaced.
If Tank bladder is low in air and not water coming out.
2-If it checks ok put an air gauge to tank to check the air pressure, with a standard 40 gal tank you will have 28 psi of air in tank for it to function properly.
May 21, 2010 | Plumbing
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Coffee Makers & Espresso Machines Logo
194 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
