Question about Kitchen Appliances - Others
Need hookup wiring diagram for 978 M South Wind Military Gas Heater Manufactured by Stewart Warner. 1950's series I have a complete heater but no wiring diagram to enable me to connect to the power and control for the unit.
I need a picture and a wiring diagram for a 978-m gas heater. my email is brid36ed62@gmail.com
Posted on Sep 29, 2013
2 Suggested Answers
  • 63 Answers
SOURCE: need to verify wiring on hatco 3sc9 sink heater/rethermalizer
hi my name is mark, leave your e-mail address and i will send a pdf file
Posted on Mar 10, 2009
What is the minimum vertical vent distant from top of water heater to top of cap. Water heater is stand alone outside furnishing water for military force provider showers unit.
Generally 40 feet for ordinary atmospheric-vented household water heater...
Straight run to roof.
Atmospheric means no power vent... just hot air drafting upwards
Google search: gas vent height code
Atmospheric venting code depends on 4 basic factors:
Diameter of vent--- bigger vent, more draft
How many water heaters are connected to same vent
BTU per hour rating of water heater-- the more gas that is burned per hour, the bigger the vent needs to be
How straight the pipe is -- are there any horizontal or lateral runs
http://www.ameri-vent.com/files/assets/files/1366372183_Sizing26ApplicationGuide1.pdf
http://waterheatertimer.org/pdf/Bosch_Checking_the_draft.pdf
http://waterheatertimer.org/pdf/checking-the-draft2.pdf
Other factors can include
-wind conditions... higher wind across top of vent pipe on roof can reduce draft, and cause downdraft that blows deadly CO into same room as water heater
-vent termination near high walls, trees, high roof peak etc will reduce draft or cause downdraft
-amount of incoming air supply... if water heater is inside a closed room, then there is no air to draft up the pipe, burner will shut down or burn lazy yellow instead of clear blue
-stuff piled up around water heater that obstructs air intake
-dirty air intake screen that reduces air intake
-vent fans inside same room as water heater that pull air down the vent and cause reduction in water heater draft
-generally elbows reduce draft by 10%
-vent cannot terminate near any window door or air intake for another gas appliance
-bird build nest on top of vent pipe after vent termination falls off
-highly acidic gas by-product causes large amount of condensation inside pipe that burns hole in pipe or drips down and damages combustion parts...blower and inline condensate trap and drain might be required
-multiple water heaters installed on same vent line.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 27, 2015 | Water Water Heaters
Should ele and gas work to gether onwater heate .dont now if we used water or gas.or bouth
Some RV water heaters are both gas and electric, depending on what hookup is available at campground.
Otherwise, water heaters are electric or gas.
Gas water heaters have a 3" to 4" round vent pipe located on top.
Electric water heaters have electric wire connected on top or side of heater, but no vent pipe.
Look at images on following link
http://waterheatertimer.org/Leaking-water-heater.html
Gene
Mar 20, 2015 | Water Water Heaters
How do you separate heater from ignition switches on 2007 Kawasake Mule 600
go to manuals.com and you might find one there
If you need further help, reach me via phone at https://www.6ya.com/expert/allen_b068623c5003aa4b
Sep 05, 2014 | kawasaki 2007 Mule 600
User manual for Rheem 21V30DV
1) 21V30DV is 2006 6-year mobile home (manufactured housing) natural-gas, atmospheric-vent water heater
2006 Manual does not show on internet.
Replaced by Warrior series
http://www.rheem.com/documents/warrior-dvx-warrior-dvx-use-and-care
http://hometips.me/Mar/Mobile-home-water-heater-illustration.pdf
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Add comment with specific question for possible help.
Mar 02, 2013 | Rheem Water Heaters
Remove high stack from Hayward H250 series pool heater
clean stack also check gas pressure sooting caused from low gas pressure plus overheating
May 25, 2012 | Hayward H250 High Wind Stack
Have a Intermatic Water heatr timer connected to our water heater (obviously)... yesterday we drained and repostioned the w/h in order to place a drain pan under it. Now...no hot water. Believe we may have...
Timer is not identified.
Open following link to help identify timer and download manual and look at wiring diagrams for each.
http://waterheatertimer.org/Boxtype.html
By-pass WH40 and T100 series mechanical timer by removing trippers from dial and moving override lever to ON position.
How to troubleshoot mechanical timer:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Water heater is electric since Intermatic does not make gas water heater timers.
Electric water heater must be completely full of water before turning on circuit breaker, or elements will instantly burn out.
Test electricity and water heater elements:
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Jun 20, 2011 | Intermatic Hardware & Accessories
I have a Series One heater in my pool system and it is now shutting off after about 3-4 minutes of operation. It will light off ok but will then go out. Any thoughts...?
is the heater a natural gas or propane heater, If propane you are probably getting a build up of soot. this is usually caused by improper installation or inproper gas supply. ocassionally if there is alot of wind it can cause a downdraft that blows out the flame. perhaps the sensor is touching a part of the heater that makes it read improperly additonally you may want to check to see that all the wires are free from touching any heater parts
May 12, 2010 | Pool & Spa
I need a wiring diagram for a Reddy Kerosene Heater Series 125T
Here is a link to a owner's manual for a RL125T ... http://12.153.20.74/manuals/110429-01C.pdf. You can find a wiring diagram on page 19. I hope this helps you.
Dec 26, 2008 | Reddy Heater RH125T Kerosene Forced Air...
Kitchen Appliances - Others Logo
253 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
