Question about RTO Outboard Motor Bass Fishing Boat Rod Reel Oil & Grease
I have a 2000, ficht 225 evinrude motor that won't start all the time. It started when I went fishing at night, used a spot light that ran the battery down to where it would not start the motor. I tried to jump start it with another battery with no success. I got the boat home charged it overnight and it started just fine. Later that week I started to go fishing and when I got to the lake the motor would not start. I have replaced the kill switch and bought a new battery to help with cranking amps. A mechanic has taken the computer out four times and sent it to a shop in Alabama. When they tested it they found nothing wrong with it. The problem still exists. I am going nuts trying to find out why the motor won't start sometimes.
I have the same problem--let me know if you find a fix! special_k225@yahoo.com
Posted on Feb 01, 2010
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Sep 26, 2016 | Light Outboard Motor Boat Bass Fishing...
115hp evinrude ficht outboard wont start
blocked jets in the carby or problem injectors
Jul 04, 2016 | Boating
115hp evinrude ficht 2000 modelover wont start,
another ecu is less than a new motor . owners choice .
Jun 16, 2016 | Boating
I have a Evinrude Ficht 135 that Runs Ok but won't go in to gear, forward or reverse. Any ideas?
Disconnect the shift cable and see if the problem is with the shift box or the lower unit. If the lower, remove the bottom plug and look for water or metal where there should be clean oil.
If the shift box, take to the marina- they were a bear. Even just for cables.
Jun 17, 2012 | Light Boating
Starting motor binding/grinding
I will try to help. As you describe the problem I wonder if the starter gear is not cut deep enough to give clearance on the flywheel or the end bushing is too short. A short bushing would allow the gear to travel too far on the starter shaft and smack the flywheel.
Also the flywheel position would change if your particular motor has thrust washers on the crankshaft.
You may not know if anyone milled the starter case or motor. Maybe if you ground off the tip of the bolts it would help.
Apr 14, 2010 | Boating
Ficht wont start cold,will with a jumper box,what
Check the voltage on the pink wire on the starter selonoid. Should have at least 10 volts while cranking, if voltage drops below 10V change the batteries, I had the same problem.
Jan 06, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
RTO Outboard Motor Bass Fishing Boat Rod Reel Oil & Grease Logo
1,076 people viewed this question
Top RTO Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a RTO Fishing Expert? Answer questions, earn points and help others
