Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I have a poulan 18" chain saw. The safety band that goes around the clutch came off. Need info on how to put it back on
  • 3 Answers
There are actually many people asking the same question on this site with regard to several different saw models and none of the answers have been very helpful....until now.
I was faced with the same dilema and finally figured it out. When you try the steps below, you'll kick yourself for not having thought of it sooner.
If you are like me, my saw just quit. The engine would start, but the chain wouldn't turn. I didn't really know what a chain brake was or how it worked. Since I tinker with things, I thought I would take the saw apart and see what I had broken. I started by loosening some bolts and prying off a metal band from around the flywheel/sprocket assembly. Before I knew it, I had taken off the brake. I then realized what the chain brake was, how it worked, and I had actually not broken a thing - I had only needed to reset the brake. Now, however, as I tried to re-install the brake, nothing would line up and it seemed impossible.
Here is the trick:
1. Take out the c-clip and remove the flywheel/sprocket.
2. Push the brake handle to the forward and locked position.
3. Assembly the brake spring/band/cover assembly back into place over the end of the brake handle. Without the flywheel/sprocket assembly in place, you should be able to easily manipulate the springs so that things align correctly.
4. Install the brake screws.
5. Pull the brake handle back to the unlocked position, thereby opening the band.
6. Reassembly the flywheel/sprocket assembly.
7. Reinstall the blade bar and chain.
8. Replace the cover.
Hope this helps. To all you yahoos who said by a new assembly or look at a schematic and figure it out, get real! You're no help at all!
Posted on Oct 05, 2010
    President:
  • 2,220 Answers
You don't list your model; There are probably over 100 to choose from. Find your model here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Open the IPL. find the "Handle,Chasis and Bar Assembly" or similar page. That is the only drawing showing the chain brake parts. If you aren't able to repair it using that your options are to find your friendly neighborhood chainsaw shop or a new saw. HTH
Lou
Posted on Sep 09, 2009
Why doesn't chain move?
pull the safety bar back towards the handle
it is a safety clutch and when pushed forward stops the chain from moving
Nov 17, 2015 | Poulan Pro Pp4218av 18" Gas Chain Saw...
Need clutch springs for a 2300av poulan
I am confused. Is it a sears saw or a poulan saw? If it is a sears saw you go to sears for the parts. If it is a poulan saw find a shop that repairs chain sawsand take it there. They will be able to find the parts you need possibly in stock.
Nov 06, 2013 | Craftsman sears 18" Chain Saw Chain (...
Barcover wont go back on
my cover melted and the band was not releasing all the way had to replace it
Oct 05, 2012 | Poulan Pro Pp5020av 20-inch 50cc 2 Stroke...
Plastic housing broken due to over tightining
I call it a clutch cover, Poulan calls it a "Chain Brake Assembly", pn 545139903 for Type 1 or 2 - 2375 WildThing.
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Poulan.com
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain and sprocket won't move. Poulan P4018WT
Poulan P4018WT Gas Saw Type 2 link below (may not be your saw - 5 to choose from):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
It has an inboard clutch. If this is your saw remove the clutch cover, bar,
chain and inspect the chain brake linkage within. Is the brake band tight against the clutch drum? If yes grasp the forward most upper handle and pull it aft (may require some force at rear extreme) until it clicks (a keeper nests in a detent). Is there a little clearance between the brake band and clutch drum? Can you spin the clutch drum now? If yes reassemble your saw.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If not post back please.
Poulan.com
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
263 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
