Question about kawasaki Full Suspension Mountain Bike Men
My 08 bf 750 Fi is backfiring and when and has no power
When I give it the gas it has no power it acts as if yo turned the gas or key off and like you are running with the choke on but it is Fuel Injected there is no choke.
  • 3 more comments
  • colbyrobe534 Sep 09, 2009
    bf 750 is Fuel Injected.
    My bf 750 is Fuel Injected, It backfires when i give it the gas it acts like it has no power runs like it is on the choke or out of gas but is not.
    Will let the dealership know it is still waranted but wont act up for them
  • 11,896 Answers
I would remove the carb,. Take it apart, and soak the carb including floats in solvent or equivelant for couple hours. Put back together after dry and adjust floats.
Posted on Sep 09, 2009
  • Nate Stansfield
    Nate Stansfield Sep 09, 2009
    Change fuel filter, check fuel pressure to determine if pump is good. Check for good spark. You can use a voltmeter to check voltage from stator
  • 10,865 Answers
Hi colby. you have a gummy carb. begin by getting a can of seafoam at any auto parts store and pour that into the tank along with enough gas to fill it up. try to follow the guidelines which i recall as one ounce of seafoam per gallon of gas.
with a little luck you will be running better than ever before.
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Problem removing engine fuse in 08 bf ford xr6 ..the 140 amp fuse has been breaking apart any tips?
Need more info.. it blows as soon as u put it in or when u turn key on or while driving it. the more info you give the easier it will be to pin point your actual problem with out just throwing money at it and hoping to fix it :-)
May 21, 2014 | Cars & Trucks
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
Losing power
Maybe not check your vacuum hose to carb.
Mar 28, 2010 | 2001 Suzuki GSX-R 750
Bike backfireing
check needle and seat also air filter
hope this helps
May 02, 2009 | 1994 Suzuki GSX-R 750 WR
Vn800 running fast on tickover
I am not sure what you mean on the "running fast" statement. If idle speed then turn the idle screw outward to slow down the idle.
The backfire is caused by turning off the ignition key when the bike is at high revs. let it idle down THEN turn it off. The backfire is there because the carb idle circuit is active anytime the piston is in motion. Gas goes into the cylinder as the bike revs down then a hot spot in the exhaust pipe finally ignites the built up gas. There is your backfire.
Is the running fast question answered? Give me more information on the problem if it isn't.
Please rate this answer. Thanks njv6!
Apr 15, 2009 | kawasaki KX 250 Motorcycles
kawasaki Full Suspension Mountain Bike Men Logo
48 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
