Question about Samsung Refrigerators
REFRIDGE NOT COOLING - Samsung Refrigerators
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main circuit board.
Posted on Sep 09, 2009
Have frigidaire my freezer is working but bottom of refridge is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Frigidaire 18.3 cu. ft. Top Freezer...
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridge not cooling in freezer or fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
May 15, 2010 | Maytag MSD2456G Side by Side Refrigerator
My refridge and freezer stop cooling fan is
check the overload relay, see the motor compressor , on side ot its body had a small box where the wiring goes in, open it and check the relay , see if still have continuity or better yet replae.
Oct 31, 2009 | Kenmore Refrigerators
My refridge is not cooling, freezer is OVER cooling model 25336808893
if you mean freezer is over cooling because of frost on back panel of freezer then its having a defrost issue and items to check are the defrost timer,defrost heater, defrost thermostat when it frost up in freezer air cannot pass to frig section
Aug 31, 2009 | Refrigerators
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
hi thanks for the question . yes look at the compressor the start relay is burnt out replace it that should solve the problem thanks the appliance doc
May 31, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
