Question about Dryers
Change the door direction on Kenmore 600 dryer
  • 10,865 Answers
Hi there. this is an easy fix. just take a close look at the hinges and screws on the door. note the size of the screws and the type of screw [usually phillips].
Now look at the other side of the door and the frame and you will see little plastic caps. pry those off. those are the screw holes to allow you to reverse the door.
now just unscrew the door and the latch and reverse everything... enjoy.
Posted on Sep 09, 2009
Kenmore 600 dryer
Your door switch for this dryer is stuck closed or defective. The door switch controls the light to come on when the door is open while it also controls the drive motor as a safety device to stop the motor when the switch is opened. Replace the Switch.
Oct 28, 2013 | Dryers
I have a kenmore 600 drier. It will not start. I checked the door switch and it clicks and turns the light off when pushed. I can here a click in the timer when I push the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore 600 7962 Dryer
Can I change the door swing? How???
I read through the product specifications and didn't see any reference to switching the door around. I have a lot of appliance repair experience and have never seen a drier with this option, only refrigerators.
Apr 07, 2011 | Kenmore 600 6965 Electric Dryer
The door pops open after about 10 seconds. We have replaced the sensor that is located on the upper left inside of the door, to no avail. Any ideas? Also, I am not sure if this is the model #..
either the hinges have gotten bent from too much weight being put onto the door when it was open or your door latch might be broken, see if the white plastic door closer on the top inside of the door catches onto the gold colored latch that is at the top part of the dryer door opening, if either one of these are damaged you would replace both as they come as a kit. here is a parts listing:
http://www.repairclinic.com/Kenmore-Dryer-Latch-Parts?z=100
Nov 25, 2010 | Kenmore 600 6965 Electric Dryer
Change swich
hmmm door switch:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 30, 2010 | Kenmore 600 7965 Dryer
I need to know how to get to the belt on the kenmore 600 dryer
i'am assuming it has a top filter,remove top filter,remove the 2 filter screws,pull the whole top toward you and lift up,disconnect the door switch,remove the 2 screws on the top inside front panel-your in-mike
Jan 31, 2010 | Kenmore 63942 Dryer
Kenmore 600 Dryer- suddenly stopped working
can you hear the motor running, if so then more than likely the belt broke, you need to unplug it ,remove the front cover, then top cover, then remove drum and you can start to restring the new belt
Oct 26, 2009 | Kenmore 600 7962 Dryer
Dryers Logo
235 people viewed this question
Top Dryers Experts
