Question about Garden
Snowblower seems weak for a 5HP
I have an Ariens SS522E 5HPSnowblower. It runs great but doesn't throw snow very well. It only throws the snow about two ft and that's powder, forget about the heavier snow.
it seems like maybe a belt problem or a throttle problem. Should this blower throttle up automatically when it hits snow? It seems to stay at an idle.
  • lucky99star May 11, 2010
    do you have a throttle control on the snowblower, have you checked the belts and chain if equipped?
  • Anonymous Mar 18, 2014
    Snow blower stops run when but to full throttle
  • 6 Answers
Check to see if there any surface rust inside the auger assembly. This will cause this problem. Also, you try a silicone spray on a painted surface.
Posted on Jan 06, 2010
  • 108 Answers
It will run at the speed you set at it may bog down a little when you hit the snow and the belt problem on the side there is a cover take it off there is an ajustment try to tighten the belt if that doesn't work you may have to replace it, thank you.
Posted on Dec 23, 2009
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Snowblower will not throw snow as far as before.
two things to do. One, get the carb service and have them check the governor.
Two, have the auger belt replaced.
Dec 27, 2012 | Garden
My craftsman 2 stage 8hp 26" snowblower won't throw the snow out the discarge shute, everything else seems to run great. As soon as to much snow builds up it just churns the sno,won't throw it...
Hello, you need to check and see if the shear bolts have sheared and are not turning the auger. Or the bronze gear in the gear box has been chewed up and is stoping under load.
Feb 06, 2011 | Garden
I have a Ariens snowblower with a Tecumseh engine. It starts easy and will run with no problem, but when the auger is running and I'm throwing snow, it shuts off within a minute without it being...
You have a carb problem.I recently worked on one of these that had the same problem.I bought a new carb for it and runs great now.
Dec 28, 2010 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
I have an Ariens 624 series snow blower and every time I use the snowblower the snow spits out of the chute. How do I get the snow to BLOW out of the chute far? I've tried tightening the cord for the...
Looks to me like your second stage is not working. If the auger is turning fine, look and see if the secondary thrower is turning. Probably a shear bold on one or the other is broken. Easy fix, but do not put your hands in there when the machine is running!
Jan 09, 2010 | Garden
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 | Mtd Garden
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Garden Logo
424 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
