Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Won't print, feeds page and one-half blank, says empty
Same excat problem as described by the initial post
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Why am I getting only half page of a copied email. Plus I always get a blank sheet of page at the same time.
Are you talking about a page printed from a printer or something on your screen? I need some more information before I can help you. It does sound like you are describing a printer problem and if it is, does this happen when you try to print anything else?
Sep 17, 2014 | Dell Computers & Internet
A700
you mus select 1 page in the box appearing, they indicate how many pages, what do you want to print?
However if the problem persist, you must uninstall, and repair the software follow the steps from uninstalling. And installing again or repair the s.installation.
God bless you
Jul 26, 2013 | Epson Office Equipment & Supplies
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
HP Officejet Pro L7580: says load paper/won't print
Go to printer and faxes and cheeck the preferences of your printer cheeck the number of copies and all strange that you will saw.
i hope my advice is helpful.
May 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
On this page
goes to my printers page right click on printer select open in print queue select print job the click on stop printing
Apr 20, 2009 | Computers & Internet
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
