Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
RCA 61w66 messed up
My RCA 61W66 picture is messed up Its probably on 10" tall total and U shaped. What could be the Problem,
    Champion:
  • 213 Answers
Lost of power supply that power up your conv.
if you tack off the back of tv look at the left of tv you see a red wire come from the flyback
you see 3fuse by the flyback down at the base
of the flyback that is power for the conv,
it could be bad solder, try that to see if that
you fix. hope this worh for you.
Posted on Sep 09, 2009
Adjust resolution on lumix dmc-tz3
Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
RCA HD 61w66 color is messed up...
problems like that is caused by moisture inside the unit.sometimes it goes back, like nothings happened.but, if not a tech is the only option.
May 20, 2009 | Televison & Video
Rca d52w20 52in. rearprojection tv monitor
Remove the back panel from the tv where the input jacks are located. You will see a red power wire. Just above that and to the right approx. 7" or so you will notice a [_] shaped metal shield surrounding a cgreen/gold capacitor. You may need to remove the plastic cover that is located directly above it about 6-7" in length to gain easy access. Run your finger over the top of the capacitor. If it is beveled rather than smooth you have found a definite solution to your problem. The part number located on the board is CP150 16v 2200uF capacitor. It will look like a tall cylinder. Good luck!!
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture too tall
first to change format push the arrow button to the left or right. if you go into piicture in the menu then go to avance picture settings then turnoff or uncheck autoformat.
Jul 04, 2008 | RCA HD56W66 56" HDTV
Rca d40w20 Hdtv
I suspect convergence ics part number startswith stks they are black and on a silver heat sink. if you could solder you could do it.If a tv shop fixed it the cost would be around 295.00. parts are 30.00 total. www.mcmelectronics has parts. to find out part numbers they are located on the board on the back.
thanks doctor video
May 18, 2008 | RCA Scenium D40W20 40" Rear Projection...
Rca hd-61w66 chassis itc222 convergence
you can get the service info at the following link. send them an email by clicking on the contact button on the lower left side. they have schematics as well as parts.
http://servicemanuals.vstore.ca/
Apr 22, 2008 | RCA P61927 61" Rear Projection Television
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
