Question about Dell Dimension 4600 PC Desktop
Won't Turn On
Just another question regarding the Dell Dimension 4600 Desktop as I was having problems that after shutting down computer the disc drives (all) would still be whirring off and on even though shut down. Now computer doesn't turn on at all. there is a little green light that is on the motherboard and stays lit for a while even though I unplug the power cord. Is this still related to the power supply?
Thanks for all your replies.
Chris.
  • sazook Dec 11, 2007
    No smell of burnt Caps. Computer did start when I put it back together but it didn't happen right away. I had no keyboard,mouse, monitor, network cable etc hooked up. Only had the power cord plugged in. It would do nothing when I pushed the power button numerous times. So, I just left it and had to attend to work. When I came back maybe 15 minutes later, the Green power was a steady color. Turned it off, put all the cables back and it started up first try. Then lately, would turn it off and the drives and fans would continue to intermittely turn on and off every 2 seconds. What are the main issues? Thanks for your help guys.
    Sergeant:
    Champion:
  • 317 Answers
All computers do that, there is always some energy that lingers on the power supply after being unplugged.
Does the power supply make a weird screeching noise or even smell like something burned?
If you can open up your PC, can you notice something burnt? like the Capacitors for example, look for something like this:
http://www.jebswebsite.com/misc_pics/ibm_mobo_capacitors.jpg
Capacitors that no longer work either leak or swell.
If this is the case, have the motherboard replaced.
Posted on Dec 09, 2007
  • Baja Data / Jay Arias-Chavez
    Was your problem solved? Do you have more information or questions?
    Please let us know so we can help you better. Better yet, give the solution a rating! :D
    Thanks!
    Genius:
  • 1,601 Answers
Yes, It shows the board is getting power (maybe not enough though)
Since I can not see your computer, run through this checklist from Dell, Let me know how you make out.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=40D4258B12DC06C9E040A68F732810A7&treeid=011360B8243248349C306481A954B356&Query=bm8rcG93ZXI=&SystemID=DIM_P4_4600&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl
I would without seeing it that the PSU is bad.
Dimension 4600 dvd drive keeps opening
Try this first - open up the BIOS part of the system. To do this, shut the computer off; wait at least 10 seconds; turn the computer back on and then press F2 when the Dell logo appears. Press continually until the message Entering Setup appears. In the Boot Order section, remove the CD/DVD drive from the boot order by clicking on Disable from the drop-down menu. If this doesn't fix it, please resubmit your question
Feb 19, 2015 | Dell Dimension 4600 PC Desktop
Have to perform shutdown twice
The problem is the computer is old. You dont need to shut it down twice. You just need to wait patiently the first time.
In any case the computer is way due an upgrade. 2Gb Ram is small fry these days minimum is 4Gb
Sep 28, 2012 | Dell Dimension 4600 PC Desktop
I can't boot up normal, safe mode, or to the cd-rom on my dell dimension 4600 desktop, i've set to boot to cd rom in bios, but still nothing
If you are trying to boot off an Windows Installation disc then you might have a problem. On some computer the CD-ROM drive won't be able to read the operating system disc.
The solution to this issue would be to put in a DVD drive and try to boot from that.
More details on the normal and safe mode boot attempts would be nice too. Are you getting a blue screen or is it just hanging up?
Jun 06, 2010 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 won't boot up and when you try to turn it off with the button it just starts back up.
It sounds like a back-up was started and now your system is trying to complete the task before it shuts down. You can turn it off by holding the power button down for 10 seconds. This will cause the power supply to shut down completely. You will lose any unsaved data and it may corrupt your back-up.
Mar 25, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
What type of CMOS battery does a Dell Dinmension 4600 use?
Hi friend,
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
If you have to repeatedly reset time and date information after turning on the computer, replace the battery. You can read anything about your dell dimension 4600 PC like....how to change the battery click on LINK
With Regards
Avnish Kumar
Jan 09, 2010 | Dell Dimension 4600 PC Desktop
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
Computer won't shut off (occasionally)
usually this the indication of Hard driver problem.
this hard drve is on its last lag. it is hardware failure.
get a new Hard Drive and copy everything to the new hard drive. save this one as a backup.
May 22, 2009 | Dell Dimension 4600 PC Desktop
Boot up
Maybe your CMOS battery is low on power. Have it replaced with a new/good one.
Hope it works for you.
Amfo_1
Mar 01, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
62 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
