Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Same as below...
I have the same problem as somebody else who posted. Our Jenn Air French Door Frig has had temperatures spike in the freezer to 37 and 58 for the frig. Everything defrosted. I've cleaned the grill below and hit max-cool to bring the temps down - it didn't work so well. Are there any other maintenance issues we should be addressing at this point or other things we should check to address the rising temp issue? Thanks!
    Scholar:
  • 106 Answers
HELLO,
Is this fridge more than a year, if it is, then I would kindly suggest, :) to have a new coolant installed, and then run the fridge some time, it should kick back to normal...:)
Posted on Sep 09, 2009
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
Can't change temperature
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 24, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn Aire frig is 6 years old and compressor is bad. Should I replace it or buy a new one?
check the warranty on the unit, if no warranties are valid anymore i would proabaly replace the unit... most compressor repairs can range from 300-800 dollars after parts and labor so its kind of whuts a cost effective way to go ...
Jan 31, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
175 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
