Question about Amana DLE330RAW Electric Dryer
The dryer drys but the dial does not move and....
It does not stop automatically. What do I do? The vent was messy but not clogged.
  • 6,784 Answers
HI. the timer control module is experiencing difficulties. the advancement of the timer dial is crucial, and it must rotate in order to initiate proper cycle sequence. The timer motor is the culprit in this case, and the timer will need to be replaced.
Replacing the timer will fix this issue.
Posted on Sep 09, 2009
Testimonial: "Thank you for the quick response."
  • 96 Answers
Timer is probably bad
Testimonial: "I was very greatfull for the quick clear response. "
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Our dryer works but it takes about two full cycles at 60 minutes each on high to dry the clothes
Sounds like the vent is plugged. Disconnect the vent hose from the vent and test again. If it drys normally your vent is plugged and will need to be cleaned.
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
The dryer takes three hours to dry a large load. It is almost one year old and it seems to take longer than it used to and the clothes don't actually get that hot anymore
is your dryer getting hot if so disconnect your dryer vent and run a normal load and if it drys that load in a normal ammount of time it is your vent pipe in the wall clogged
Mar 16, 2010 | Maytag Dryers
Dryer runs but on Automatic Perm Press the dial doesn't move and it literally is drying 8+ hours later. What should I do?
If its electric sounds like electric heater coils need replaced. Also check to see the vent hose isn't clogged with lint. That will restrict the air flow hence longer dry time.
Oct 17, 2009 | Dryers
Still drys but not as fast as it once did
Hello.
You have one of two problems with your unit.
1. The vent hose is kinked behind the unit and restricting air flow from the dryer.
2. The vent going outside is clogged somewhere between the wall and the outside.
Once you fix either of these two problems the dryer will work good again.
Jul 14, 2009 | Dryers
It takes usually 3 complete cycles to dry an average load of clothes.
try taking the vent hose off your dryer and running it through a cycle with it off...if it drys ok then you have a clog somewhere in your venting.
Jun 22, 2009 | Roper REX5635E Dryer
Dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Gas dryer wont trun off after drying
May 08, 2009 | Dryers
I have whirlpool gold ultimate care 2 the dryer is heating but not getting real hot
You may be having a venting issue, disconnect the vent from the back of the dryer,if it drys normally then you have a clog in the vent line too the outside, if still takes too long too dry you may have a bad operating thermostat on the blower housing.
Jul 16, 2008 | Whirlpool Dryers
Amana DLE330RAW Electric Dryer Logo
138 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
