Question about HP LaserJet 3150 All-In-One Printer
Some, not all faxes being sent are received to light to read or a mostly black page.
    President:
  • 3,085 Answers
You have a bad SCANNER BLOCK, uneconomical to repair it. Sorry
Posted on Sep 09, 2009
Receiving faxes alright, people receiving faxes from us are getting an all black page
Your document scanner has died. Meaning that the row of LED's that light up to scan the documents you are trying to fax are not lighting up. The result is a scanned document that is read as all black. Make a copy....you will get a black sheet because the same process is used to scan the document when making copies.
It might be time for a new fax machine as these machines have become so cheap to buy new that I doubt you could get this machine repaired for what you can just buy a new one for.
Good Luck and Thank You for using Fixya.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Black pages received when faxing to others
Your scanner array is bad. This is a light "bar" that lights up to scan your originals before they are sent out. You can test for this by making a copy with your machine. The same scanning function is used to make a copy as it is when you scan to send a fax. If you make a copy and it comes out black then your scanner is bad. This is especially true as when you say that the problem goes away for a short time after turning the machine off. This allows the circuit to cool and the solder connections to shrink and make contact. As the board heats up the metal contacts expand and "open up", causing the scanner to fail.
Not a cheap fix unfortunately.
Mar 16, 2010 | HP LaserJet 3050 All-In-One Printer
Black page when copying and sending faxes.
You most likely have a bad SCANNER BLOCK. Not good!
Dec 23, 2008 | Brother IntelliFAX 4100 Laser Fax
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Sent fax
the question is Why can't they read it????????
compressed, dark, light.......???????????
Aug 19, 2008 | HP 1010 Plain Paper Inkjet Fax
Canon i-sensys fax-L100
The machine keeps in memory only reports of faxes sent or received until the page is full.When the report page is full, the earliest fax is removed to make way for the most recent. Therefore if you sent enough faxes after 4 Apr 08 to fill a page, there will be no record.
Aug 18, 2008 | Canon FAX-L1000 Plain Paper Laser
Fax Machine Problem
the glass strip is bad, this is what reads the fax.
look in the manual under Maintenance for the location
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=6e9b3b779afac7942ef639a6224550b2&q=Sharp+UX-P100
Jan 30, 2008 | Sharp UX P100 Plain Paper Thermal transfer...
Problem with sent faxes
CIS SCANNER SEEMS TO BE BAD TRY CIS TRAINING FUNCTION IN THE MAINTENANCE MODE AND DO CIS TRAINING USING A PLAIN WHITE SHEET/(FUNCTION *2864 , USE 55 CODE TO DO THE CIS TRAINING) OTHERWISE REOPLACE CIS SCANNER. HAPPY FAXING OMNIPRESENT
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
HP LaserJet 3150 All-In-One Printer Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
