Question about Sanyo DP32746 32 in. LCD Television
My Sanyo Vizio can't find any input
Sanyo Vizio can't find my input and message on the screen instructs me to press channel up to look for digital channels. I can't press restart, menu, or anything. Just channel up.
    Champion:
  • 213 Answers
Try to reset tv
Posted on Sep 09, 2009
Press channel up and let it go through channel search, when done- do it again, after second time it should go to inputs
Posted on Sep 12, 2009
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
HOW DO I GET A CHANNEL ON MY TV AND GET THE MESSAGE "NO SIGNAL" OFF THE SCREEN?
If it shows "No Signal" it means it. It do not get any signal to display. Check all the settings. Refer its user manual for details. First, try to tune it to on-air program, by do an auto-tune function, after connecting it to an external antenna. Refer its user manual for more details. If it do receive all the channels transmitted, means, the set is OK, and the fault will be with the input selection, you've done. OK?
Gopakumar Gopalan Google
May 02, 2014 | Vizio Televison & Video
No channels in Master List message on Vizio xvt3d554sv with Dish Network Satellite...what to do?
I had this same problem. My TV had sound and the lights were on but no picture. The screen said "No Channels in Master List."Here is how I fixed it:1) I made sure that my Dish Remote was on the TV mode (when pressing down buttons, the TV button would light up).2) Once that was confirmed, I pressed 03 to ensure I was on Channel 3.3) (this was the hardest part!) I found the remote that came with the TV. I never use it so it was hard to find...4) I pressed the Input button and selected the correct Satellite option. On my TV, that option is: "HDMI-1 Satellite"5) The picture was restored!
Aug 19, 2011 | Vizio L37 Television
What does D03-1 mean
The TV has several inputs, Video 1, Video 2, HDMI, etc. One of the inputs is Digital. TV stations switched from broadcasting analog signals years ago. You may remember having to buy a digital antenna, or possibly if using cable or satellite service never knew it happened. You can press the input button on your remote until you see D03-1 on the screen and then do a channel search. You may pick up some extra channels that are being locally broadcasted for free in your city.
May 21, 2011 | Sanyo DP46849 46 in. HDTV
The screen has a message "No channel in Master List" on it. There is no picture or sound.
tv is on the wrong input, just press the input button on the remote or the tv that should fix it for ya
Jun 08, 2010 | Vizio P42HD Television
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Mar 21, 2009 | Vizio VX20L 20 in. LCD TV
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
Dec 02, 2007 | Sanyo DS31520 31" TV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Sanyo DP32746 32 in. LCD Television Logo
241 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
