Question about Brother HL 1250 Laser Printer
Paper feed not collecting paper, clicking noise
    Problem Solver:
  • 6 Answers
Clean the pickup roller(s) (in the paper tray) with mild soap and water if you can remove the pickup roller easily or with a q-tip if you can't. DO NOT USE alcohol as it will dry out the pickup. Use at least two q-tips, don't stop cleaning too soon. You can use a little fine steel wool to rough up the roller surface too. Replace the rollers if that doesn't work. Usually cleaning them is a stop gap measure. This works for the top rollers too.
Posted on Sep 09, 2009
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
My brother HL-5240 won't feed from paper tray, only manual feed. It makes a clicking noise. Toner is newer, definitely not empty. I've tried all the tricks of removing some paper, using different paper,...
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol.
Jan 28, 2011 | Brother HL-5240 Laser Printer
THe printer is making a screeching sound as the printed paper comes out. I also appears that the print quality is lessened and areas of pink speckles. It is not telling me to replace the drum, or waste...
hello, you say you here the noise when its printing, how about when machine is powered on, or when the front door is closed, and the machine is cycling up. the reason behind this is to check to see if the problem may be with the consumables. one thing then to try is run only the test page, from the control panel, if the noise occurs try to pin point it, if its from paper feed or maybe the fuser area. the fuser might be making noise due to the bearings that are in it. if from the paper feed then it might be the front door assembly, so try feeding from the manual feed tray, and see if that also makes noise. if it is then the front door assembly, will need a good looking at. now i still have not covered fans on this machine or the actual laser unit if this machine, way too much to look into. so i need more info. okay, i forgot, when the paper is exiting machine, before printing, open up back cover, cheat the cover switch, and run test page, i had forgotten that the section of this machine, has a unique output assembly, that is driven by small gears, i have found that this unit makes noise as well as paper jams, so if you run machine with the back cover open, the paper will just fall out the back, but you will not hear any noise, so this output might be the problem, i have only run into this problem twice. so this try it.
Dec 08, 2010 | Brother HL-4040CN Laser Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
My Samsung CLP300 has a paper feed problem. When
Lift up the front of your machine about 4 inches with a book.
The paper will now feed easier.
Richard
Oct 27, 2009 | Samsung CLP 300 Laser Printer
Clicking noise with MFC-8640D another case
Usually it's because the paper is too tight in the feed tray. The paper length tab on the end away from the feed roller is too tight. If you cant rotate the gear on the paper tray and lift the paper, it's too tight for the machine to lift.
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother HL 1250 Laser Printer Logo
298 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
