Question about Philips Magnavox 15MF400T 15 in. LCD Television
No sound. Not on mute. Did smell a slight burn when it happened. Sound stopped suddenly. Looks to me like a catastrophic component failure. I would like to get it repaired. Great picture and I also use it for a computer monitor. Where can I get repair? Thanks
    Champion:
  • 213 Answers
Pc board is bad the tuner it is on the board . need to be replace.
Posted on Sep 09, 2009
Maytag Neptune MAH5500 smelled like burning plastic at the end of the cycle. (The whole basement smelled bad.) The smell seemed to be coming from the plastic part at the top where it latches.
Tub bearings get worse, if they faulty, the machine would be noisy and getting louder. Sudden burning smells usually mean an electrical failure of a component but if this has stopped and the machine is working properly, its possible that something has got caught up in the rim of the tub or gasket area and during spin it has got "burnt" by being dragged around the edge. Have a close look at your clothes that were washed on that day for signs of burning or damage and around the top at leading edges of the tub for signs of melting or damage.
Mar 21, 2017 | Maytag Washing Machines
My sound system had a smell of burning from the main unit and suddenly stopped working. I switched it off and now although all the function lights are on there is no sound from the system but no longer a...
radios often have components that over heat and burn out. Once burned out they have to be repaired or replaced. Ford F150 trucks are notorious for that.
Mar 02, 2015 | Cars & Trucks
How do I get the sound to work on Sony bravia tv that suddenly stopped working
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 24, 2015 | Sony BRAVIA Televison & Video
Strange hissing sound and smell comes from the monitor
Whenever you experience an unusual smell coming from anything electrical, always turn it off and/or disconnect it from any power source until you learn more about the problem. A fire can make make any problematic device seem suddenly unimportant.
An extremely common component in nearly any electronic device is a capacitor. The sizes vary from baby-tooth-sized to bowling-ball-sized found in the power box for most photography studios. The hissing sound is likely caused by one of these. The noisy capacitor may be going bad or another component or an electrical short may be causing it to get too much power. I've attached a video of what happens when capacitors get too much power.
An electrical short could also be causing both symptoms. If the smell is similar to burning organic matter, you likely have an insect (a crispy critter) that can be removed to remedy your problem. However, an electrical burn usually releases gases from burning rubber or plastic and has a distinctly different type of odor. If that's the smell and you are handy with a soldering iron, remove the cover to your monitor and look for signs of burning or overheating. Otherwise, the task should be left to an electronics shop for repair.
If this information was helpful, please click the thumbs-up button below.
Oct 23, 2012 | LG Computers & Internet
I have a two year old dryer that all of a sudden there is a loud rattling sound in it and slight burning smell. I'm not sure if that smell was there before but it's almost as if there is somthing inside...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Amana ALG331RAW Gas Dryer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Winding sound, with a smell of burning
I recommend to stop the use of the dryer immediately and call an expert repairman to your home. The smell of burning can only mean bad things, so better safe than sorry.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
No sound No picture slight but audible buzzing in flyback. That says it all. Fuse is OK Brown on circuit board around Large heat sinked transisters. "assumption these may be regulators" Can not...
Take it apart and check the low ohm resistors around the flyback
and see if your horizonal Transistor is short,Do a diode test on the juntion of the Horiz-transistor does it read low ohms from collector to ground,with set unplug.Let us know
May 11, 2007 | Emerson EWF2704 TV
Philips Magnavox 15MF400T 15 in. LCD Television Logo
183 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
