Question about GE Dryers
Dryer works good at first then shuts off
After it cools down it will run again untill it gets hot again. It's a DBXR463EG1WW
  • 304 Answers
This is usually caused by a motor getting too hot. The motor has a shutoff to protect it against burnout. It will reset when it gets cool. As the motor overheats more and more these shutoffs become more frequent and longer
Motors get hot for several reasons:
  1. Motor going bad
  2. Lint around motor causing it to retain heat
  3. Vent system open at some point inside or behind case allowing heated air to remain in motor area
Follow the procedure below to disassemble and check interior of dryer. Vacuum carefully especially around and in the ends of the motor.
Disconnect power.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screw and raise the top.
Look down inside the open top dryer from above on each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top and then lifted off the bottom clips and swung away to the right from the case. Be careful not to strain any wires connected between the case and the front.
This will expose the underside of the dryer along with motor and venting for checking and vacuuming. Perform thorough vacuuming and reverse the above process for reassembly.
Posted on Sep 09, 2009
Starts and runs for about 20 seconds then stops
Sounds like your motor is going bad, runs until it gets hot then shuts down, after a little cool down it will run again. Eventually the motor will just seize up for good. Good Luck!
Jul 18, 2015 | Dryers
Model # dbxr463eg1ww, dryer overheats and stops sometimes, only on reg heat, after cools off starts right back up. Sometimes it goes thru cycle and sometimes it stops again. Top of dryer gets very hot to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | GE Dryers
LEA30AL Amana Electric Dryer will run then automatically shut off like it is getting to hot then won't start again until after it has a chance to sit for a while
sounds like you have a bad motor,itried looking up your model number but it's not the full number,could be a thermister in there but usually when the dryer heats up and dies it's the motor
Feb 06, 2010 | Amana Dryers
The dryer runs for a while then shuts off. after it cools down I can re-start it but it will shut down again after a while. now it won't do anything when I try to use it.
you motor on the dryer is going out. all of the motors used in dryers and washers have a thermatic protection switch so if the motor heats up too much it will shut itself off to prevent fire. once the motor has cooled down it will restart until it reaches that set temp. in the motor then it shuts down again. You will need to replace this motor
Good luck hope this has helped you some
Dave
Jan 24, 2010 | Roper REX5635E Dryer
Have a 90 series kenmore dryer, won't always run. replaced the motor about 6 months ago, and now it will sometimes run, sometimes not. It gets hot, and will run for a bit then shut down, then start up...
If the timer is not advancing but is ticking that could be the problem. A dryer achieves a set temperature and stays there for a certain amount of time during a cycle. If the time never changes it may just keep heating up until the heat sensor shuts it down. If it is starting and shutting down its likely still related to the heat sensor.
Dec 07, 2009 | Dryers
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
