Question about Canon PowerShot S80 Digital Camera
Lens the lens is not coming out of the camera
  • 214 Answers
Clean the surroundigs of the lens den blow air around it it may work
Posted on Sep 09, 2009
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
I need your help please, I fell with my Nikon camera, the body still works, but the 55-200mm lens does not work again, for seeing through the viewfinder the image is dark. The lens does not hit with...
Okay if you have luck all that's happened is you have jarred the lens contact between the camera body and lens. Make sure the camera is turned off then remove the lens and clean the gold contacts on both the lens and camera body. Remove the battery, install the lens and replace the battery, turn the camera on. If it still doesn't work shut the camera off and try another lens and see if it work properly this will tell you if it's the camera at fault or the lens. Switch lenses between known working cameras. I'm sure you will find the lens has come loose. I only once had a lens come apart from a jar (not impact) and it actual popped apart in pieces.
Dec 10, 2010 | Nikon D60 Digital Camera with 18-55mm +...
The camera turns off
allienment of lens unit with the mother board/may be problem with the sensors of the lens unit
Mar 02, 2010 | Kodak EASYSHARE M763 Digital Camera
An error FEE Flashing comes when the camera is turned on
What lens?
If it's a CPU lens, remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts.
If it's not a CPU lens, you'll have to use it in the Manual (M) mode.
Oct 04, 2009 | Nikon F60 35mm SLR Camera
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
Digital camera lens cannot come out. Restarting required
Feb 03, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot S80 Digital Camera Logo
129 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
