Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer - electronics kaput
I did 3 loads of laundry this morning...the last wash finished but the door remained locked. I figured out how to take off the bottom panel and release the door manually to get the clothes out but cannot get the electronics to come on again. No lights. No button controls. Can't run the diagnostic program. The fuse was blown and I reset it but the washer still does not come on. There is no click when I plug it into the socket (the manual says to listen for a click to tell if the CCU is working). I checked the socket and it is fine. ANY suggestions will be much appreciated. Do I need to replace the CCU? Is this something a non-professional can do? Or is it time to call Sears for repair? Thanks in advance!
  • 6,784 Answers
HI, the CCU has failed in this unit. I recommend that you acquire the professional services of a qualified service tech for this repair.
replacing the CCU will correct this fault.
Posted on Sep 09, 2009
Testimonial: "Much appreciated -- thanks!"
You can buy the board on Ebay for under $200 and if someone has any ability at all they can replace it in an hour. I did mine and save $290.00. The part is likely W1016442 a Whirlpool part.
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Door locked no power
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock. On some machines it maybe be required and sometimes easier to remove the bottom kickplate and access the lock assembly from there
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool control locked
Power shd be on. Press and hold "end of cycle" button for 3 seconds. Always wait for 2 minutes after the wash is over for the machine to release the door lock; an inbuilt safety device. Never force washer doors, you'll have probs.
Check out your filter too.
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool duet
On the far right sode of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear.
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
131 people viewed this question
Dan Webster
Dan Webster
Sal De
