Question about Kenmore Elite HE4 Electric Dryer
Dryer will not switch out of jean mode.
No matter what different cycle buttons are pressed, dryer will not switch from jean mode. I am at a loss.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Swith off power for 5-10mins. If this does not reset it the problem is in controller
Posted on Jan 01, 2008
Whirlpool duet dryer stuck on steam cycle
one trick to stop the steam is to remove the water hose connected to the dryer
Nov 20, 2013 | Whirlpool WED9500T Electric Dryer
Whirlpool Duet gas dryer won't turn on
It seems that the button is defective. This is something that will require a technician to check out.
Jan 24, 2013 | Dryers
Dryer "control locked" light on.
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Apr 08, 2011 | Dryers
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
May 24, 2009 | Electrolux EWED65H Dryer
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Doesn't stop
The problem is probably the plunger switch that you press to start the dryer. If you select the OFF position and then move the dial to a cycle, does it start running without you having to press the start button? If so, that switch is your problem.
If you disconnect the dryer and remove the rear panel, you can unplug the switch and repair it yourself (the contacts probably just need to be adjusted) or you can replace it. Depending on the dryer you might be able to get the part number from the inside cover of the rear panel.
Apr 17, 2008 | KitchenAid KEYS750LQ Electric Dryer
GE DPGT750GC Gas Dryer Problem
Using the
To locate Troubleshooting Tips for common dryer
Press the HELP button.
2 On the Touch Screen, select TROUBLE
3 On the Touch Screen, select the problem
description from the list. You can use the arrows
at the right of the screen to scroll up and down
through the list of additional problems.
4 On the Touch Screen, select a possible cause
for the problem and follow the on-screen
instructions to find a solution.
Pressing the HELP button then selecting HOME
allows you to find additional
information on features found on the Home
Screen. Touch any pad on the Touch Screen for
an explanation of that feature. To exit the feature,
press the BACK button.
Attach the serial cable for washer and dryer
connection to the serial port on the back of
the dryer.
Attach the other end of the cable to the
washer before pushing the washer into its
final position.
Problem Possible Cause What To Do
Dryer won’t operate Control panel is asleep • This is normal. Press POWER, the
touch screen or any button to activate
the control panel.
Dryer is unplugged • Make sure cord is plugged securely into
a working outlet.
Controls are not set properly • Make sure the cycle was set correctly,
close the lid and press START.
Fuse is blown/circuit breaker • Check house circuit breakers/fuses.
is tripped Replace fuses or reset breaker.
NOTE: Electric dryers use two fuses
or breakers.
Electronics need to be reset • Unplug dryer, wait 2 minutes, plug
back in and press POWER.
START was not pressed after • Press START.
a cycle was set
Door was opened during • Close the door and reset cycle, to the
the dry cycle beginning if necessary. Press START.
Dryer is too cold • If the dryer has been exposed to
temperatures below freezing for an
extended period of time, allow it to
warm up before pressing POWER.
Otherwise, the display will not come on.
Hope some of this helps. here is a link to the manual:
Nov 29, 2007 | GE DPGT750GC Gas Dryer
Whirlpool Gold Dryer
You will need a volt Volt-Ohm (VOM) reader to fix this problem.
This doesn't rquire sound technical knowledge for this but you should be good at following some instructions.
This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
  • Fuse could be bad -- Check the fuse for a break inside. If it’s bad, replace it with an identical fuse.
  • Temperature switch could be bad -- Use VOM to check the switch. Set VOM to RX1, remove leads and touch the probes to the switch's terminals. The reading should be zero or infinity. Turn the switch, and the reading should change from zero to infinity or infinity to zero. If not, the switch is bad.
  • Thermostat could be bad -- Set the VOM to RX1, take a lead off one of the two outside terminals and press the probes to the two outside terminals. There should be a reading of zero. If not, it's bad.
  • Heating coils may be bad -- Set the VOM to RX1 and remove the leads from the coil. Press the probes to the terminals. If the reading is zero, the coil is bad.
  • Timer could be bad -- Disconnect the leads from the motor. Set the VOM to RX100. Clip the probes onto the leads. If the reading is infinity, the timer motor is bad.
Oct 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore Elite HE4 Electric Dryer Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
