Question about Refrigerators
WATER SPERTS OUT OF WATER DISPENSER WITH NO CUP PUSHING LEVER
    Scholar:
  • 106 Answers
HELLO,
The cup pushing release lever is most like loose, it could be easily replaced and then the water spillage is no more...:)
Posted on Sep 09, 2009
Water dispenser not pouring water and same for the ice dispense, but still making ice.
Probably switch that is activated by the cup lever at the dispenser.
May 12, 2015 | Refrigerators
How do you remove the in the door dispenser cup and lever for cleaning
Depends on the make/model, but usually there are a few screws that go in from the front that hold the plastic arms in place along with the spring blade. Most of the time you need to remove the decorative plastic cover around the front of the dispenser to get at them. Pay attention to how things go together, or take pics before and during the process. It will save you a lot of headaches later.
Mar 20, 2015 | Refrigerators
Why is the water running directly into the ice dispenser and running out of the door when we are not pushing the lever to get water?
Sounds like the water valve is stuck or the wiring or switch is defective. As both ice and water are a problem it sounds more like a defective water valve.
Oct 05, 2014 | Whirlpool Refrigerators
GE refrigerator water dispenser won't stop after lever released
water valve in dispenser in bad,, check with store for possible replacement ,,or maybe the shut off valve isn't open all the way in water line connection
Jan 20, 2013 | Refrigerators
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Water dispenser lever (where you push the cup in) has popped out
I made the repairs by the seat of my pants and --yes, it's all fixed now. It sure would've been easier if I could've removed the face plate to the control panel to get access to the problem underneath. I hope I solved your other user's problem with the water dispenser.
Larry
Apr 05, 2009 | KitchenAid KSCS25FKSS Side by Side...
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Water dispenser will come on at random times
are you talking about the lever where you put your glass to get water or the ice compartment if it where you put your glass to get water it could be that if the pressure is not strong enough to close the valve after you have taken a glass of water or a defective solenoid vavle thanks from gilles
Jan 17, 2009 | GE GSS20IEP Side by Side Refrigerator
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Water dispenses without pushing lever
There is a solinoid valve that opens when you push the switch in. It has apparently failed and is leaking. Sometimes taking it apart and cleaning it will fix the problem.
Jan 28, 2008 | Kenmore 53542 / 53544 Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
