Question about HP PSC 2110 Color Printer
The printer will not power up. Everything is
The printer will not power up. Everything is plugged in properly, was using fine, then went off a few days ago & won't power up now. Is there a reset button or anything?
  • 58 Answers
If no power, try to check the plug fuse first.
Posted on Sep 09, 2009
Epson rx585 wont power back up
open the cartridge campartment and check for any insects or dust clean and try to restart
Apr 03, 2014 | Canon MP560 All-In-One InkJet Printer
My lexmark x5470 printer will not turn on. We had a huge thunderstorm and everything went out but it is the only thing that wont turn on right now.
Try first to remove the black box.Used a clean and dry paper clean the metal plate on the area where you plug it in ,clean also the black box specially the metal plate .Then try to remove the power cord from the black box clean the ports clean also the cable .Try to return it back make sure its properly plug in .Try to used other power outlet in case no go .In case no go probably its the power supply inside the printer
call lexmark
  • International & USA Lexmark International, Inc. 740 W. New Circle Road Lexington, KY 40550
  • 1-800-(539-6275) -----------------------asked them for a system replacement in case you are Out of warranty be irate and probably they will escalate your case and grant you a system repalcement or even upgrade .....................
May 31, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer won't turn on and everything is plugged properly
in that case please follow this step
1) Power Code Check first if its working not perfectly so please change it.
2) if Power Code working fine then other thing is that may be some problem with Printer Hardware may be due to short board its not working need to repair this.
May 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printer won't turn on ( mx850 )
I believe the fix is to disconnect power cord for an hour or so.
This is truly maddening... it's a bug in the design of their power supply.  It's happened to me three times in the past few months.
The first time it happened, I haplessly stumbled onto the solution wisdos mentioned (unplugging it for a while) without realizing it.  I thought it just started working for no apparent reason.
The second time I tried all sorts of tricks (not remembering the fact that I'd disconnected the power for a period), spoke with Canon support several times and finally had to agree to have them send me a replacement printer.
I'll skip the part about not being able to get the old printer's print head and inks out to put in the new one because it wouldn't budge without the power being on.
Now, with second printer and a five-second power failure, the same deal... won't turn on.  This time I pulled the power cord from the printer and let it sit for a few hours.  Plugged it back in and it came on.
The maddening thing is that Canon support didn't want to escalate this to someone who might understand the power supply and diagnose the problem properly... their solution was to send out a new printer.  What a waste of time, money, and effort.
Jun 21, 2009 | Canon PIXMA MX850 Multifunction Printer
Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
May 03, 2009 | Epson Stylus Photo R800 InkJet Printer
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
GE Fridge/freezer not working properly!
hey ur thermister has worn out may be due to the power surge when the power came back at that time so change the thermistor then check it out.........
Sep 09, 2008 | Refrigerators
EPSON V700 Photo Scanner
Unplug the power supply from the power port on the scanner then plug it back in after a few seconds and power-up if it isn't already on. This happens to me a lot and this works every time. Frustrating though.
Jan 14, 2008 | Epson Perfection V700 PHOTO Flatbed...
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
HP PSC 2110 Color Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
