Question about Electrical Supplies
Generqator stalls The generators starts but does not keep running. It quits or stalls after several minutes.
  • 5,660 Answers
That's a fuel system problem.
(Depends how old it is, but it should have Electronic Ignition. Electronic Ignition usually just goes out all at once)
Start diagnosing with the simple stuff first.
1.Check the air filter. Make sure it hasn't become wet. (Rain) Make sure it is clean.
A clogged air filter from being soaked with water, or clogged shut from dirt, will have the above symptom you listed.
2.Gasoline engine:
A.Some have a sediment filter installed in the bottom of the gas tank. Screws right up into the tank, then the fuel hose connects to it.
Observe whether the fuel tank is clean on the bottom.
Sediment will disperse throughout the tank when the engine is not running, then collect around this filter after the engine has run for a while.
Result, is clogging the filter until no fuel can pass through.
(Engine running, fuel is brought through the sediment filter. Engine off, the sediment falls back onto the fuel tank floor, leaving the filter open enough to draw fuel through again)
[I have also seen the rare occasion, where someone put a raw egg in the gas tank, to stop a gas tank leak.
(?) Don't ask me, I have No idea!]
B.Be sure the fuel tank ->cap has the vacuum orifice open. This orifice allows air to enter as fuel is being drawn out. If the tiny orifice is clogged shut, a vacuum is made in the fuel tank, and the engine starves for fuel.
C.Check the inline filter in the fuel hose. (If this model uses an inline fuel filter. If no inline fuel filter is used on this model of generator, I would advise buying one, and installing it) See if air will pass through. (Use air hose on compressor)
Make sure the filter is installed in the correct direction, There is an IN and an OUT. (OUT to carburetor)
3.Diesel engine
I would advise taking a generator with a diesel engine to the shop, but you can check the air filter, fuel tank for sediment, and also check the inline fuel filter, first. (If it has one)
Posted on Sep 09, 2009
Testimonial: "I greatly appreciate these tips and ideas. I will try them out as soon as possible. thank you very much."
  • 615 Answers
Make sure the on/off to the gas tank is on and no craks in the gas line. aslo check and see if you have any slack on the governer's spring
Testimonial: "The vent for the gas tank is on. I appreciate these ideas amd will check them out as soon as possible. thank you"
2000 aratic cat 400 4x4 runs 5-10 min. if the battery is charged, but then stumbles and stalls. checked when running and the battery voltage keeps dropping till it quits. what can it be?
Charging system is not providing necessary current and battery is getting draqined. Need to diagnose charging system and do a complete battery check at the same time.
May 30, 2014 | Harley Davidson FLHT Electra Glide...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
Generac 6500 1988 in R.V.Southwind Two things, both only occur in the morning or when cold (I am in So Cal so not that cold). First, when starting the generator from the dash board starter button the light...
See if there is an oil pressure guage on the dash. When you start the machine it probably has a low oil pressure shutdown which shuts the engine off when you release the start button. This is an interlock. Watch the oil guage and keep the start button engaged until you see oil pressure, release the button and it will continue to run at that point. Your second issue may be a function of the choke. If you are having to choke the engine to start, you may have to play with the choke position to keep from overfueling the unit which may cause it to stall and possibly backfire as it has to much fuel to be burned on the compression stroke, and is igniting occasionally on the intake stroke. Hope this helps. Marvin
Jan 20, 2010 | Generac 5622 GP Series GP5000 6,250 Watt...
Shorted out generator??
they do smoke if its petrol lol joke sounds like a short circuit check the connections
Jun 08, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
318 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
