Question about Akai LCT3285TA 32 in. LCD Television
Akai remote codes are what.i need code 4 the tv remote
    Scholar:
  • 23 Answers
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shackakai remote codes are what - 2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Posted on Feb 18, 2010
  • 58 Answers
Akai codes: 0051 0301 0671 0741 0851 0871 0991 1001 1491 2371 2391 2551 2751 2791
You may setup the URC by the following code entering instructions.
1. Refer to the DEVICE CODE LIST, look up the 4-digit Device Code which
corresponds to the brands of your A/V equipment. If there are more than
one Device Code listed under your brand, try from the first code.
2. Press a desired Device Mode Key
3. Hold down “ CH+ ” and “ VOL– ” on the URC together simultaneously for 2
seconds until the indicator lights up.
4. Use the number keys to enter your 4-digit Device Code, the indicator
should go out immediately.
Turn on your device (e.g. TV), try the function keys on the URC. If your device
(e.g. TV) responds to your invoked function correctly, you have entered the
right Device Code. Otherwise, repeat the above setup instructions with the
rest available Device Codes until your device (e.g. TV) responds to your invoked
function, and most keys work correctly.
Posted on Sep 09, 2009
4 Suggested Answers
SOURCE: remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Posted on Dec 30, 2008
SOURCE: Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Posted on Mar 16, 2009
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
Need code for akai tv ge unversal remote model
0382,0333. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 14, 2014 | Televison & Video
Need to program remote for akai
Hello
You want to programme your Akai TV with a universal remote control; I assumes, and posts this solution.
Three digit universal remote codes for Akai TV are:
002/ 0030
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Feb 03, 2012 | Televison & Video
Akai lct2715 directv remote code
I can help you with your Akai LCD TV & DirecTV remote control.
This is a list of all the Akai LCD TV control codes for DIrecTV remote controls:
11675, 11676, 11688, 11689, 11692, 11693, & 11935.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
Apr 28, 2010 | Akai LCT2715 27 in. LCD Television
Need 4 digit remote codes for this tv
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Dec 29, 2009 | Akai LCT3701AD 37 in. LCD Television
Universal remote codes
HI,
Please provide me with the model no. of your remote so that i can let you know if there are any codes available for your akai tv.
You can also check out :
http://www.avico.com.au/products/
Apr 09, 2009 | Universal Remote Control GE174Universal...
Need set up codes for cft 2790 akai tv
Dec 31, 2008 | Akai CFT2490 24" TV
AKAI TV WITH J&E RC24912-D UNIVERSAL REMOTE FOR AKAI TV NEED CODE
The codes for AKAI TVs, according to the manual, are 003, 177, 195, 201, 202, 295
Nov 03, 2008 | GE JASRM24912 Remote Control
Remote code for Akai 37" lcd with Dish Network
Akai support 216-454-0864 .I have the same problem and called the support phone. The answer is this TV came without a code programmed in it.
Aug 17, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai tv remotes
Jan 06, 2008 | Televison & Video
Akai LCT3285TA 32 in. LCD Television Logo
612 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
