Coleman Mach III Air Conditioner
Problem for Coleman Mach III Air Conditioner
My coleman mah 3 roof top will not blowon fan side
By rollinrid on Sep 09, 2009
My coleman mah 3 roof top will not blow on fan side and on ac it makes a humming noise and nothing.
Best Solution
posted on Sep 09, 2009
Very Helpful)
hiltonjug
Rank: Guru
Rating: 92%, 219 votes
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Coleman Mach III Air
Questions and Unsolved Problems for Coleman Mach III Air
Do you recommend Coleman Mach III Air Conditioner?
Answer
Answer
Replaced condenser and had health problems. Now cant find wireing diagram to reinstall. Thank youfor... (More)
Answer
installing to volvo 36ft bus need installation requirements for water drainage, electrical and... (More)
Answer
water is entering through unit. i think the previous owner sealed around weep holes. how do i fix or... (More)
Answer
I have a coleman top unit in my travel trailer the wires running from the thermostat are red green... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
