Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Won't start I have an 18.5hp B&S single cylinder engine in my Craftsman tractor. It ran the last time I put it away and now it won't start. It turns over strong but it has no spark. Can somebody help me? I did some tests to check out the coil and it seems to be working.
  • 96 Answers
Did you check the air gap between coil and flywheel? did you change sparkplug
Posted on Sep 09, 2009
float or float valve sticking in seat.
Aug 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding lawn mover with new battery but doesn't start.
When was the last time had valves adjusted.
Jun 26, 2013 | Craftsman Garden
Won't start, apparently due to low compression. Any easy solution besides replacement?
First verify the compression is below say 90-100psi. A four stroke engine will run on compression technically as low as 70psi, but will dog for power under load. It depends what kid of engine it is, if it's an "L" head which is a single cylinder engine, it should be very easy for someone mechanically inclined to replace the head gasket. I doubt there is enough piston ring wear in something that new.
May 20, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
My 26 hp craftsman tractor stalls and won't start when it gets hot
being that would be a twin cylinder engine and has two sep coils does it missfire before it dies?does it have spark when it dies?does it sputter then die like it runs out of gas where the cap vent could be plugged and it vapor locks if you spark carb cleaner or starting fluid the solenoid on the bottom of the carb shutting off that should give you something to start with
May 01, 2012 | Craftsman Garden
Yard tractor has 145 hours ran 2 weeks ago but was missing ,it had backfired,changaed plugs,fuel pump works,seems to get spark,won't start even eith gas put into cylinders
You may possibly need to adjust the overhead valves in the engine. Your owners manual should have the steps included in it (under maintenance) to do this. This is quite possibly the problem. The valves should be checked and adjusted once a season just to be sure.
Aug 12, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 16hp B&S, 42 tractor. engine surges, blows oil
SOUNDS LIKE YOU HAVE A AIR LEAK AND SOME BAD GAS AND YOU MAY WANT TO CHANG THE OIL 1 MORE TIME LETME KNOW IF THIS HELPS IF NOT ILL DIG IN TO IT WITH YA
Oct 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Does a 19hp crasftman lawn tractor have a oil
IF IT HAS AN OIL FILTER IT WILL BE VISABLE FROM THE OUTSIDE OF THE ENGINE. IF THE ENGINE IS A SINGLE CYLINDER IT SHOULD NOT HAVE A FILTER TO THE BEST OF MY KNOLLAGE THEY PUT FILTERS ON THE TWIN CILINDERS
Sep 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
470 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
