Home | HP | OfficeJet G85 All-In-One InkJet Printer | Readoout says
HP OfficeJet G85 All-In-One InkJet Printer
Problem for HP OfficeJet G85 All-In-One InkJet Printer
Readoout says
By don_wooldrid on Sep 09, 2009
readout says "scanner malfunction. turn machine off and back on to reset. which, of course, doesn't work.
Solution #1
posted on Sep 09, 2009
Not Rated)
Gort007
Rank: Guru  HP Computer Hardware  Expert
Rating: 89%, 460 votes
1. Turn machine OFF and unplug electrical cord from wall or power strip.
2. Turn ON printer without the power cord plugged in (this will discharge the power capaciter in the printer).
3. Plug electrical power back in and turn on printer...
4. It should have reset.
Another possibility:
The scanner arm has the physical "lock" switch in the locked possition. Turn OFF printer and move the switch to the unlock position. Turn on printer.
This switch is for whenever the printer is moved to a different location and will protect the scanning bar.
Hope this helps!
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet G85 All-In-One
Questions and Unsolved Problems for HP OfficeJet G85 All-In-One
Do you recommend HP OfficeJet G85 All-In-One InkJet Printer?
Answer
Answer
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from... (More)
Answer
cartidge alignment failure on HP officeJet G85xi -- how do you fix it?
Answer
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone... (More)
Answer
Half empty black cart stopped printing, error message to replace. New cart also didn't print. ... (More)
Answer
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP OfficeJet G85 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
