Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2001 Road King battery low after long ride.
Battery old so picked up a new one and installed . Turned on ignition and hit starter everything went dead. All fuses check ok. When i turn on the ignition the panel lights don't light up and nothing lights check run /off switch it ok.
First things first - obtain a factory repair manual for this bike.
So, the new battery became weak after a long ride? The first thing I would check is a small component that causes nagging problems with older bikes - the rubber socket connector that connects the stator to the voltage rectificer/regulator. At the bottom of the frame tubes just in front of the crankcase you will see your voltage rectifier/regulalator. From it you will see a pair of wires that connect to the outer primary with a rubber socket. Note, if you are looking at the front shifting peg this rubber socket is immediately behind it and pointing towards the front wheel.
These sockets loosen with age and oil contamination. They can pop off while riding, and unless you have a voltmeter (such as the FLHTC does) you will not know that you are losing a battery charge until the lights go dim and the bike begins to run poorly. If this plug has popped off, do the following:
Disconnect the battery ground cable so there is no current flowing. Use some spray brake (or electronic component) cleaner to wash any oil from the rubber socket, and the short rubber plug that protrudes from the primary. Gently blow them dry with some compressed air and allow both to dry thoroughly. Reconnect the socket to the plug and make sure there is a positive connection.
This will happen again in time, and a decent and inexpensive repair is to use a piece of heavy preformed stainless-steel wire that is fastened to the primary and bent until it presses the socket securely in place. These are available from aftermarket suppliers.
Now, if this is not the problem, then a deeper investigation is needed. For this, you will need a simple voltmeter that can measure AC and DC volts.
If the socket is intact, it should be carefully removed in order to visually inspect the terminals. If there has been any arcing berween the terminals it will be quite apparent.
If the terminals appear good, then either the voltage regulator or the stator has a malfunction. The good news? The testing of both items is relatively easy but it involves a bit of technical know-how and access to a voltmeter that can measure both AC and DC volts.
Make sure the battery of the bike is fully charged and has 13.2 volts DC present at the battery posts. Connect the battery to the cables; positive first and negative last.
To test the stator - disconnect the rubber socket and and start the bike. The voltmeter should be set to AC volts for this test. Be very careful and touch each lead of the voltmeter to the terminals of the protruding rubber plug. There should be at least 14 -30 volts AC present at idle. Note - this test should not require the engine to be operated for more than one (1) minute. Prolonged operation with the socket disconnected can damage the stator! Let's say that the stator passes the test.
Turn off the bike and reconnect the rubber socket to the plug. Start the bike and take it for a ride, and take the voltmeter with you. After riding for thirty (30) minutes or so, make sure that you are again home before you stop the bike. Keep the bike running and set the voltmeter to DC volts. Test the voltage at the battery terminals. The voltage shown should be a minimum of 13.2 volts and a maximum of 14.6 volts. If these values are correct, then the voltage regulator and the stator are functioning correctly.
Finally, if the stator is faulty it must be replaced. This is not a task for a novice as it requires a couple of special tools and the ability to safely generate a lot of wrench torque. If the voltage rectifier/regulator is faulty is is quite easy to replace be merely disconnecting it and unbolting it from the bike.
The problem with the rubber socket and plug is well-known. The inability of this conector to "stay put" can ruin the terminals inside the socket and plug, and short-circuit the stator. This will kill a stator, so it must be taken seriously.
Good Luck, and Best Regards,
J. Forbus
Posted on Oct 18, 2009
That sounds like a bad connection. follow the positive and negative cables around and insure good connections. lack of lights and dash panel info is a sign of bad connection or hate to say bad battery. if you had lights and dash lit up i would start at the starter area next.
Posted on Oct 06, 2009
My 2006 road king Harley won't start after riding over a curb
You didn't describe the "click"
A series of rapid clicks means a low battery, or a bad (usually ground) connection, like if you crunched/abraded a wire along the lower frame when you drive over a curb.
A single, loud click indicates its a bad starter relay, about a $12 part:
http://www.ebay.com/itm/Starter-Brake-Relay-Switch-Harley-ROAD-KING-1991-2011-repl-OEM-31504-91A-/390652043658?pt=Motorcycles_Parts_Accessories&fits=Year%3A2006%7CModel%3ARoad+King%7CMake%3AHarley-Davidson&hash=item5af4ad218a&vxp=mtr
Nov 25, 2012 | 2006 Harley Davidson FLHR Road king
1999 road king ignition fuse location
Hi Anonymous, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, starter and ignition relays will be under the seat behind the battery, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck and have nice day.
Sep 29, 2012 | 2000 Harley Davidson FLHR-FLHRI Road king
What is causing 2005 flhrsi road king custom speedometer to malfunction.
Check first the FUSES, clean the terminals of the fuse and replace if already blown.
The intermitent location of the speedo means a trickle of voltage going into the system. The malfunction came when your charging the battery w/o removing the terminals.
Check and clean the harness connection.
Tell me if there is some more problem.
Nov 13, 2011 | 2005 Harley Davidson FLHRSI Road King...
I have a 2000 yamaha xv1600 roadstar. Went for a ride and made a stop. Everything started and ran great. After the stop I went to crank it up and heard a funny noise near the starter and the nothing. ...
Hi, Pawpaw36507 nice novella and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2000 Yamaha XV1600 Wild Star fuse panel location Google Search
Re Fuse box Road Star Forum Yamaha Road Star
Yamaha XV16AL Service Manual
OEM parts for Yamaha
YAMAHA XV1600A Owner Manual
Mar 07, 2017 | 2000 Yamaha XV 1600 Wild Star
Put a new battery in a 2005 Road king and it is draining the amps and killing the battery. the voltage regulator is good and the starter is good and the battery is brand new.
Is it draining the battery when parked up or riding with the lights on? If it is with the lights on and riding, check the altenator if when parked up check if there is a wiring problem or a faulty alarm if fitted.
Mar 28, 2011 | 2005 Harley Davidson FLHR - FLHRI Road...
Speedometer quit working i checked the sensor and it came out clean
My speedo went out while riding. It would bounce up and down then stopped completely. The odometer still had power but would register no miles. A local mechanic suggested to check the battery cables. While this seemed odd to me, I checked and found them loose. After tightening them up the speedo and odometer worked fine. Apparently the voltage connection to the speedo was hit and miss. So far everything is working great.
Mar 07, 2011 | 2001 Harley Davidson FLHRCI Road King...
Lands Phones Logo
564 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
