Question about Acer Aspire 5610-4648 Notebook
Need to reboot acer aspire without recovery disc
I don't have the recovery disc. I read to hit alt F10 but that's not working. It says windows is loading files and then it brings me to another boot menu, but then back to the acer screen. Any ideas?
My acer laptop does boot up it keeps shutting down after the acer screen what can I do
Posted on Sep 09, 2009
  • 615 Answers
Try in bootup using delete or F2 or F8 one of them should work for safe mode is the F8 for the mem the other two. good luck
Recovery cd for acer aspire 5332
Mostly Acer machines come with a partition installed in them, basically if you cant boot to windows, you can simply hold down Alt Key and Continuously tap the F10 key immediately after booting up the unit to get to the recovery mode.
Or you can simply contact Acer for the Recovery CD's.
May 27, 2011 | Acer Computers & Internet
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
How to restore my laptop without a recovery disc? (acer aspire 5100)
Hi
You could try hitting the f10 key at the top of your keyboard as soon as you start the computer that should take you into factory restore to start with it looks likes its loading windows but in about a min it takes you into the option to take back to factory settings
If f10 dont work try alt\f10 or the blue fn\f10
if none of them work hit the delete key on startup and go into bios to make sure that f10 is not disabled because sometimes it is by default disabled
But be very carefull not to alter anything else in the bios or you could and probably have big problems just enable f10 0r f12 if they are disabled then hit save click yes
windows will then restart and try the f10 key again
good luck
Nov 13, 2010 | Acer Aspire 5100-5022 Notebook
Reboot to factor sttings without disc
Try hitting ALT+F10 at startup. I believe that is Acer's recovery key sequence. Let me know if you have continued problems.
May 27, 2010 | E-Machines (T2958) PC Desktop
I did a windows update and now my aspire 5920 wont start. have tried in safe mode with and without internet but still nothing happens. i don't have a recovery disc can anybody help?
Turn on your laptop n try pressing Alt-F10....n try restart it....generally acer laptops work properly after pressing Alt F10.....
Also if u r able to turn on ur laptopn in safe mode then try deactivate windows update...and restart ur laptop in normal mode.....
Mar 13, 2010 | Acer Aspire 5920-6727 Notebook
How do i erase everything off my acer laptop ? by rebooting ?
Go to acer recovery.This can be done by hitting Alt & F10 together as soon as the computer starts.
Hit hard disc recovery.
Dec 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
Want to restore my Acer aspire 4720z!
From Acer direct
If you see this:
Jun 02, 2009 | Acer Aspire 4720 Notebook
ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
reboot and hit the alt and f10 buttons at same time and follow the prompts
May 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5610-4648 Notebook Logo
529 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
