Question about Canon PowerShot G3 Digital Camera
LCD monitor is blank
The LCD monitor on our G2 is blank when we attempt to use it.  We've tried pressing the display button, recharging the battery, taking the battery out and replacing it, etc.  This happened in a matter of minutes.  We were using the camera with the screen on and taking photos.  We turned everything off and perhaps 10 minutes later when we went to take more photos the screen remained blank.  Is the LCD feature totally kaput?  (We can still take photos, but can't view while taking photos or in the playback mode).  Any suggestions would be great.
yeah i have the same problem on a G3
  • Anonymous Dec 25, 2008
    The LCD screen is blank when I open it up, but if I twist it towards the front of the camera it works just fine. If I twist it back, it goes blank again. Happens when I'm taking pictures and in playback mode as well. Any help will be most appreciated.
    Genius:
  • 1,689 Answers
Canon would have to fix this for you. The fault may be the screen itself, or the LCD viewfinder drive IC on the camera's circuit board. In this case they will replace the circuit board.
Jerry G.
Posted on Apr 13, 2008
Lights come on, but blank screen
Hi estees823,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 20, 2011 | HP Pavilion dv9000z Notebook
Hi there, although the led comes and I can hear the disk running on my Samsung G2/640 hard disk; I am unable to view it or use it - PLEASE HELP!!!!!!!!
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
4. Try to reinsert the memory module/s (RAM) of the unit or simply use a good working RAM. A faulty RAM will cause the laptop not to POST.
Hope this helps.
Jun 13, 2011 | Samsung G2 Portable External HX-MU064DC/...
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
Screen going blank on system boot and on switch off/on
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a fraction of seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 08, 2010 | Sony SDM-HS75 17" LCD Monitor
Blank LCD laptop does turn on
I beleave you may need to press the function key as well as the F-4 key to bring up an external monitor.
Try holding down the Function key and tapping the F-4 key while watching the screen on the external monitor.
Is your unit within warranty, HP offer an extended 1 year on top of your normal 1 year warranty for video and motherboard issues.
Hope this has helped.
Sep 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Display battery level
Well, I tried pressing and HOLDING down the mode button. The battery level display miraculously showed up. I’ve also read (yahoo answers) that battery level display will show up automatically when battery is low. Hopefully I won't have to do this every time I recharge the battery.
Mar 17, 2009 | Kodak EasyShare M1033 Digital Camera
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Dell d600 video problem
Forget the non-sense.
  2. Open the RTC Battery compartment
  3. unplug the RTC battery
  4. Press the power button to dissipate stray voltage
  5. Re-install RTC battery and cover
  6. re-install main battery
  7. Re-boot and enter set-up to change date time etc.
Apr 17, 2008 | Dell Latitude D600 Notebook
No display
as your power supply is ok check hor. section if it becomes ok you will get voltage on g1 &g2.
Aug 16, 2006 | Philips SoHo 105E 15" CRT Monitor
Canon PowerShot G3 Digital Camera Logo
462 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
