I think it's the drain line or something, but I cant find where it's pooling up at... We only stay in dry climates, so I know it's not a high humidity issue.
Comments:
Sep 09, 2009
- 5th wheel is not "perfectly" level, but only one door swings a little.
Your AC's drain port could be on the opposite corner from where the water is building up. Your vehicle absolutely has to be level, this pertains to the refridgerator also. Good luck, my friend, Dana
I built a 70W solar panel. The cells are housed in a wood frame and topped with plexiglass put down...
(More)
I built a 70W solar panel. The cells are housed in a wood frame and topped with plexiglass put down with a bead of silicone to seal all tight. One only 1/4" drain hole on back underside to drain moisture, and permit air to get in or out due to thermal expansion and contraction. On hot sunny day, the cells heat up as they work, and create a significant amount of condensate on the inside of the plexi. Perhaps I need a lesser amount of "air" indside the panel box, and I'm considering sandwiching the solar cells between 2 sheets of glass with no drain. Do solar cells need room to breathe?
appears to be condensation leaking from the roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back...
(More)
appears to be condensation leaking from the roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back bed and floor. Thanks, Richard
We just bought a 1996 motorhome that has the solar panel on top of the ac unit but someone has...
(More)
We just bought a 1996 motorhome that has the solar panel on top of the ac unit but someone has clipped the wires in air return and removed the Solar Monitor light assembly. I have good voltage coming from panel but need this unit to go between panel wires and battery wires. Where can I get this assembly or does anyone know where I can get a part number for it. Thanks
