Question about HP Officejet Pro L7580 All-In-One InkJet Printer
HP Office Jet Pro L7580 - Control Panel stopped working. The printer and scanner works through the computer, but I can't use the control panel to copy, scan, fax, or even shut off the unit.
  • wa6247 Sep 09, 2009
    Thanks for the suggesetions, but my issue is not with my computer control panel, but the control panel on my printer.
    President:
  • 828 Answers
Read this forum my friend:
www.yboyandrei.com/ctrl_loop
got the idea to look at the .cpl files in system32 & got my problem also solved like yours.
This forum will help you a lot to open your control panel.
100% sure. Good luck!
Please rate me.
Thank you.
Posted on Sep 09, 2009
  • Francis Mark Arango
    Francis Mark Arango Sep 09, 2009
    I see & understand my friend, in this case of yours, physically your Hp Officejet has a problem, the thing is the control panel are not respond even you shut off. I suggest if this printer is warranty, bring it back to where you buy it or to the HP Computer Center to fix it.
    They will reprogram & reset the memory of your printer and at this time only HP Technical Expert can do that. I'm sure 100% will be back normally your printer working.
Office jet 4500 smudges
HiYou may need to do a maintenance check on your printer.Go to control panel and click on printers and scanners..There should be an option to do a clean...If you do a roller and nozzle check this should stop the smudging
Hope this helpsKind regardsMichelle
Feb 23, 2012 | HP Office Jet 4500 G510n
Can I received fax on my pc for my HP office Jet Pro 7580L
Hello.
The Fax can only be received and printed from the unit.
If you have a 56k modem in your PC with a phone line input you can set up a fax through windows. Simply go to control panel, printers and faxes and follow the instructions to install a fax driver.
Then you can receive the fax directly to your PC without having to go through the HP Printer at all.
Regards GM
Aug 01, 2011 | HP OfficeJet Pro L7580 Color All-in-One...
I am trying to scan from a HP Officejet Pro L7580. I am a bit of a technophobe and the printer is telling me No Scan Options Refer to device documentation which I havn't got. PLEASE advise me on how to...
Hello Mr.Johnson !
You can start a scan from a computer or from the control panel.
To use the scan features, your device and computer must be connected and turned
on. The printer software must also be installed and running on your computer prior to
scanning. To verify that the printer software is running on a computer running
Windows, look for the device icon in the system tray at the lower-right side of the
screen, near the clock. To verify this on a computer using the Mac OS, open the HP
Device Manager, and click Scan Picture. If a scanner is available, it will launch the HP
ScanPro application. If it is not available, a message appears to let you know that a
scanner was not found
Here you will find a link that will take you to this printers service manual (device documentation) :
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Hope this can help you
You can contact me directly on:
eliteprintersolutions@gmail.com
Good Luck
Jul 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My HP 8500 stopped printing my Quickbooks 2009 checks. It worked fine for about 5 months and then stopped. I installed updates for both Windows and QB 2009 and reinstalled the HP drivers for my printer but...
click on start go to control panel. go to pritners. click on add a printer option on top of window. then add a local pritner. add deskjet 990c drivers use existing ports
Dec 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My computer won't reconize my software it has found the computer
I have miss place my CD for my Office Jet Pro L7580. I am trying to add to my mac computer. Is there a way to add to my mac without the CD?
Nov 11, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Black Ink won't print
Try cleaning the printheads:
On the control panel press Setup>Select Tools>Select Clean Printhead
If that doesn't work, try manual cleaning the printhead contacts. This begins on page 147 of the User Guide.
L7580 User Guide
Nov 03, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
173 people viewed this question
Seeker5211
Seeker5211
