Question about Canon PowerShot A540 Digital Camera
Problem with my rechargeble battery with my Canon Powershot A540.
Every time that I want to use my camera, I always have the battery warning for low charge. I change my rechargeable battery ( 2550 mAh ), also the charger and after a few shots and I can't do many hours because the warning appears....and the point , I'm not the only one with that same kind of problem.
  • Canon Master
  • 4,738 Answers
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Posted on Sep 09, 2009
Canon PowerShot A530 Digital Camera My problem is everytime I insert new battery in my camera the indicator is always low battery... And when I turn it off and on again sometimes full battery.. Is there...
Hello
If the batteries are indeed new batteries and you are continuing to get this low battery warning, there is a defect within the camera. However, it may or may not be critical.
Test out a new set of batteries, if they last you a typical amount of time, the error is a false reading and can be ignored. However, if the batteries drain at an advanced rate, there is a short in the camera and it will need to be sent in to Canon for service.
Mar 19, 2011 | Canon PowerShot A540 Digital Camera
I got this camera a few years ago for Christmas and unfortunatley it is the worst camera I've ever had as far as battery life. I can take 2 or 3 pictures and then it shows low battery. I've replaced new...
It seems there is some where inside the camera leakage.. Are you using Li-ion rechargeable batteries or AA batteries For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
Jan 08, 2011 | Canon PowerShot A540 Digital Camera
Every time I turn on my Canon A540 Powershot I get the black date/time screen. The date/time is all zero (the photo properties default to 1 Jan 1980) and I have to either enter the date/time or press...
Inside the battery compartment, right beside the AA batteries, there's a tiny little door labeled CR1220 (see this picture). Pry the door open with your fingernail, remove the little button battery located there, and take this battery down to your local drugstore to buy a replacement camera clock battery. Remember, it's a "CR1220" battery. It should cost only about $4.
Dec 29, 2010 | Canon PowerShot A540 Digital Camera
The low battery warning light flashes even when the batteries are fully charged. We tried several different batteries and it still does it. The camera will stay on for 15 minutes and then it will shut off
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info:
Apr 26, 2010 | Canon PowerShot A570 IS Digital Camera
I bought the best rechargable batteries and it still has low batt
Apr 25, 2010 | Canon PowerShot A530 Digital Camera
Battery life poor.if battery voltage drops below 1.4 volts low battery warning starts and a couple of pictures later camera shuts off.I use only alkalane AA cells.
HI there its a symbol of poor battery condition. So i suggest you replace with a new rechargeable battery for your camera & resolve the problem. Thanks,
Apr 07, 2010 | Canon PowerShot A540 Digital Camera
Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Oct 03, 2008 | Canon PowerShot A540 Digital Camera
Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
May 27, 2008 | Canon PowerShot A540 Digital Camera
Battery low light
Jan 27, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
210 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
