Where is my "previous channel" button?
I have a Moteva RC5002 remote control for my Mitsubishi TV everything is fine except I don't know how to go to a previous channel so I can click back and forth between 2 channels. Can you help?
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
  • 3 Answers
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
Posted on Feb 12, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
SOURCE: Channel stuck on TV
This may work;
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Posted on Oct 27, 2008
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
How to program my decibel electronics jumbo universal remote to my comcast cable box
I pushed code search different blink appeared pressed tv press code then use on buttons. On all the code
Dec 20, 2012 | Televison & Video
Previously Requested but no solution: I cannot reprogram the remote for this TV so that I can connect to AT&T Uverse Satellite. I do not have a mdoel number for the TV remote that came with the...
Hello, Mr. Ross.
I'll be more than happy to assist you with this and all of your other Uverse concerns.
First please write these codes down, these are the TV codes for your Mitsubishi TV,
0093, 0150, 0178, 0019 (we are going to do trial and error for these codes till we hit the correct one for your TV.)
Please turn the TV on and point your ATT remote control.
Okay, using your ATT remote control, please press and hold the TV button together with the "OK" button.
All four modes should flash twice indicating that we are programming your remote control.
Now, enter the 4 digit code and the selected mode (in our case it is the TV) should give a long flash.
Then press OK.
Try to turn your TV off and check if it would respond
If not, please redo the steps but this time use the other codes I provided earlier.
If these codes wont work we will do the automatic code finder if you are using the "black" AT&T Uverse remote control.
Using your ATT remote control, please press and hold the TV button together with the "OK" button.
Then press the "scan/ff" button repeatedly with atleast 1 second interval till it turns your TV off.
Press OK then try to turn your TV on again.
Whenever your remote won't respond, try pressing either the AT&T button on top of the remote before any other buttons or the TV button beside the ATT button.
Aug 10, 2011 | Mitsubishi Televison & Video
My remote control works fine except Input
Ur remote CPU is shorted.Try website 1-800-Remotes Factory original.To buy an exact remote.Could take the remote aparts,clean the circuits board with some alcahols with some Q tips.Might get the remote work,but doubted.
Apr 09, 2010 | Sylvania LC320SLX 32 in. LCD TV
RC00013 remote, channel change and power not working, how to fix?
hi,
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
regards,
kaybicks
Feb 27, 2010 | One For All URC-4605 Remote Control
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Mar 13, 2008 | RCA RCR460 Remote Control
RM-AV2100
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
