If you see no connecting bolts and no mounting bolts then this piece is pressed together. Make sure you have removed the mounting bolts that hold the piece to the Trimmer as sometimes they use the mounting bolts to hold two pieces together to reduce weight.
I am not sure which gear housing you are referring to. I put a link here to a page showing the diagram for the Troy-Bilt TBAH 41AJAH-C711. I do not know if this is the same model you have but it clearly shows the gear housings and all the attachment points. If this is not the the same model you have please include that info. Or if you are referring to how the trimmer attaches to the drive unit please include that model#
It would also be helpful to know exactly what you are trying to do with it. Thanks
The part I require is worn out and no longer holds the the gear box together. It is NOT shown in the Parts diagram that is in the Operator's Manual or any other Parts diagram that are provided on the internet. The Model is as you correctly state TBAH 41AJAH-C711.
The gear housings I refer to are made up of four parts:- Item #3 753-04654 Housing (L), Stick and Item #16 753-04667 Housing (R), Stick which attach to Item #23 753-04674 Housing (L), Blade and Item # 25 753-04676 Housing (R), Blade
The required part as I stated is in two pieces, they fit over bearing # 18 located between Item #10 753-04661 Washer and Item # 38 753-04840 Washer. The two parts are held in place with a rubber "O" ring.
I hope this clarifies the situation.
Thanks.
