Question about KitchenAid KSRS25IL Side by Side Refrigerator
Failure all cooling suddenly failed, fan running, compressor hot to the touch, no frost on the coils in the freezer.no prior warnings.5 or 6 years old. help!
  • laloyd Dec 12, 2007
    got a repairman out this am and you nailed it exactly! relay...
  • gotalemon Dec 14, 2007
    We have had nothing but problems with this refrigerator and it is only
    3 years old. Every year the same thing happens, the freezer and frig
    gets hot and stops working and we have to throw out all the food. I'm
    ready to dump this refrigerator, it was not worth the money.
  • 410 Answers
Compressor is hot but is it running. one likely thing i would check is the start relay on the compressor.
Posted on Dec 11, 2007
I have a kenmore elite 795.77549600 and it's not cooling like it used to the compressor is very hot to the touch and one of the lines is frosted over what could it be? Cleaned fan and coils too help!!
This can happen if the freezer fan is not running or you have excessive ice build up from the unit not defrosting. Check to see if the freezer fan runs by pushing the light switch in the freezer and look for frost build up on the freezer back panel.
Apr 24, 2015 | Kenmore Refrigerators
Kbra22kmss fan never stops freezer has frost
adjust the thermal level switch to normal position
Aug 01, 2012 | Refrigerators
Refrigerator running but not cooling
Check list:
fan motors all functioning
Cooling coils free and clean
Compressor cool to the touch
(compressor blazing hot bad relay)
Backside of freezer section frosting up
(bad defrost heater,thermostat,or timer)
Small line from compress is HOT
(cool high pressure line means low charge)
Suction line frosting up (overcharged)
Generic ice box Training manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 17, 2010 | Kenmore Refrigerators
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Not cooloing
I would request you to re-check to see if both fans are running, the condenser fan by the compressor and the evap fan in the freezer. Next, empty the freezer and remove the evap cover. look at the evap coils. Are they completly frosted up -- if so, you have a defrost problem - this will cause the condition you describe- IF they are not frosted, are only a few of the passes of coil frosted and some just wet with no frost? Then that means you need some freon. The fact that you have some cooling means that the compressor is probabaly OK.
Hope these would help you to fix the issue.
God Bless.
Jul 09, 2009 | Avanti 248Y Compact Refrigerator
Side by side (KSRB25FHSS05) loosing cool in freezer
your compresor is hot but is it running at all or is it just humming trying to start and the just clicks off if it is just your overload that is tripp you need to replaced it that the box connected to the compressor on the left side that is why not is cooling if is running then is cheaper to buy a new one since the 5 year warranty on the compressor has expired
Nov 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool el7atrrkq01 won't cool
First, please re-check to see if both fans are running, the condenser fan by the compressor and the evap fan in the freezer. Next, empty the freezer and remove the evap cover. look at the evap coils. Are they completly frosted up -- if so, you have a defrost problem - this will cause the condition you describe- IF they are not frosted, are only a few of the passes of coil frosted and some just wet with no frost? Then that means you need some freon. The fact that you have some cooling means that the compressor is probabaly OK.
Sep 01, 2008 | Whirlpool EL7ATRR Refrigerator
Kenmore Refrgierator is not cooling enough
Is the frost on the entire surface of the evaporator or just a portion. If it is only frosting on a portion there is a possibility your system has developed a leak and has lost some of the charge. Or your compressor has lost its ability to pump the gas. A bad condenser fan motor overtaxes the compressor and can cause premature failure. If it is a bad compressor it may be time to replace the refrigerator. Replacing the compressor is an expensive job and the warranty is only one year on a replaced compressor.
May 31, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
104 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
