Question about Fuji FinePix J10 Digital Camera
My camera doesnt turn on n the battery is fully charged
    President:
  • 2,761 Answers
There may be something more serious wrong with the camera, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, wipe both ends of the batteries with the cloth, and reinsert them into the camera. This clears the problem about 90% of the time - I hope it works for you.
Posted on Sep 09, 2009
Sony Optical Zoom Steady Shot DSC-W530 wont turn on
Try another fully charged battery first of all. It might be a poor or damaged connection.
If another battery doesnt work, then its the camera.
If the camera doesnt come on the mother board is damaged. You will have to have the manufacturer change it out. Might be expensive
Mar 05, 2014 | Sony Cameras
Doesnt turn on
Are you sure the battery is fully charged? are you sure you did remove the USB cable?
When your camera is still connected to a charger or computer you can't switch it on.
And even fairly new batteries, can stop working.
Try to charge the battery several times, but if after a few attempts nothing changes, I think you need a new battery.
Jan 23, 2014 | Nikon Coolpix S3300
Samsung sl605 wont turn on
A charging battery's light is red. If it turns green then it means it is fully charged. Since you had stored your battery for a while, try to charge it by using a battery charger to kickstart it. It should work. Whatever transpires let me know. thanks and rate this answer.
Dec 24, 2011 | Samsung SL605 Digital Camera
I didn't turn off the camera before taking out the battery. Now it wont turn on after reinserting the component. What can I do? The camera is the stylus 7010
Try to plug it into your computer using the usb cable and turn it on from there. If it doesnt work, fully charge the battery and try inserting it again after an hour.
Oct 15, 2010 | Olympus Stylus 7010 Digital Camera
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Ok so my camera turns on the light is on so its charging but when the light goes off it doesnt turn on. what does that mean
I'm not sure exactly what it means, but here are a few steps to solve the issue. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 31, 2009 | Kodak EasyShare M863 Digital Camera
I own a Sony DCR-HC47E Handycam.It will not turn on
i have a problem with my sony dcr-sr47 camcorder it wont charge the battery camera works fine with power supply any solutions.
Dec 15, 2009 | Sony DCR-SR47 Camcorder
Emprex DSC5100Z camera doesnt turn on.
Here are the steps:
clean cloth.
3. Without the memory card,turn on your camera.
If issue persists camera needs to send for repair,visit www.emprex.com
Thanks.
Regards,
Neerak21
Sep 25, 2009 | Emprex DSC5100Z Digital Camera
Smasung D75 Digital Camera
Remove the battery first and leave it turned off for half hour reconnect the battery and that should reset the camera and it should work.
May 22, 2008 | Cameras
Fuji FinePix J10 Digital Camera Logo
54 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
