Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Ran over somthing with lawn mower now it wont
Ran over somthing with lawn mower now it wont start, check flywheel key its ok
    Problem Solver:
  • 14 Answers
You're right to check the flywheel key - are you certain it's ok? Also our instinct is to tip the machine over to clear the obstruction, which can send oil to places it shouldn't be! Does the machine have compression? It's possible to break the con-rod if you hit something really solid. You can check the piston's still moving by taking out the spark plug and inserting something like a cable tie in the plug hole. As you turn the engine over you should be able to detect the piston moving up and down. The jolt could also have dislodged coke in the engine that could foul the spark plug. Try fitting a new one. Come back to me if none of these solutions work..
Posted on Sep 09, 2009
Mower won't start
If this is a push type mower, most likely is has sheared the flywheel key and bent the bent blade caused the vibration. The blade will need replaced and likely the flywheel key.
May 06, 2014 | Garden
If the key on flywheel is broken will shaft on mower still turn
yes it will its on tight, they are easy to remove though stick somthing under it to pry with now with a hammer hit the other side and top of the flywheel turn round and round till it pops off
May 12, 2013 | Mtd Garden
B&S 18HP will not start
check compression squirt a shot of starting fluid in the carb see if it wont start check all your safty switchs
Apr 24, 2013 | Briggs & Stratton Garden
Lawn mower timing is messed up
Are we talking ignition timeing or valve timeing? if it is kicking back on the starter rope it has probably sheared the flywheel key ( has the mower blade hit somthing in the lawn ) also iof the blade bplt is loose this will also cause it to kick back.
Jan 11, 2013 | Poulan Pro 22" Self Propelled High Wheel...
Briggs and stratton 3.5 ran out of oil now it wont start
You might check the Shear Pin. If it's damaged at all it can cause this type of problem. It's located under the Flywheel, on the Crank Shaft.
Jul 04, 2012 | Garden
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
Ran over metal coathanger, mower stopped ,removed coathanger and mower will not start, whats wrong ?
Souns like it may have sheared the flywheel key, this is a failsafe to stop it bending the crankshaft, remove the flywheel and check the key, it is alluminium, you may need a special puller to remove the flywheel as it is on a taper.
Jun 09, 2012 | Craftsman Garden
Hit rock and stopped mower. The blade isn't bent or loose but the mower will not start. It turns over seems to almost catch but not quite
If it hits somthing hard enough it will shear the flywheel key, which will knock the ignition timing out, to replace the key you will have to remove the flywheel, there are special pullers to aid removal of the flywheel, these can be purchased from your local Briggs dealer.
May 12, 2012 | Sears Garden
Wont start
Check the blade bolt is tight, if the starter kicks back it may have sheard the flywheel key, to check this you will have to remove the starter and flywheel.
Apr 16, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
429 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
