Question about HP LaserJet 1022n Printer
Networked 1022n print job will not delete - HP LaserJet 1022n Printer
5 Suggested Answers
  • 320 Answers
SOURCE: HP Laserjet 3050, 2605dn, 1022n
do your printers have built in print servers? go into printer properties advanced settings there you will find what is called priority default for this is 1 on hp change this setting to a higher number and this should improve your response time to print
Posted on Sep 11, 2009
SOURCE: there is a print job in the printer. I cant delete
I turned everything off for an hour, unplugged everything, then re booted and hey presto!
Posted on Nov 12, 2009
michaelshaun
  • 126 Answers
SOURCE: our hp laser jet 1022n will not print jobs they
if the printer in ready mode then please follow this instrution from the below URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601512&cc=us&lc=en&dlc=en&product=439323
MAKIE SURE THAT THE PRINTER IS ONLINE
AND IT IS SELECTED AS ONLINE
THE PRINTER IS SET AS DEFAULT PRINTER
hope your issue gets resolved
thanks
regards
hamid
Posted on Feb 20, 2010
Patzky
  • 240 Answers
SOURCE: Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
Posted on Mar 25, 2010
Hp laserJet 1022n printing multiple copies when copies are set to 1
Had this same problem found a working solution here http://www.tomshardware.com/forum/59912-3-1022n-printer-stop-printing.
Just disable bidirectional support in the printer properties worked for me
Jan 06, 2012 | HP LaserJet 1022n Printer
I'm printing labels on my printer. After each run, the printer prints out an hp advertisement page for buying supplies, etc. Almost like a test page. How can I delete this annoying and wasteful...
Try this:
But first print a configuration report.(contain IP address)
Configuration Report
Release GO after LED begins blinking.
Now:
Reset the factory default settings (cold reset)
Turning on the printer while pressing the GO and CANCEL JOB buttons restores the factory default settings.
1 Turn off the printer.
2 Press and hold the GO and CANCEL JOB buttons.
3 Turn the printer on and continue to press and hold the buttons until all three LEDs are blinking.
4 Release the buttons.
Jul 13, 2011 | HP LaserJet 1022n Printer
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
You can uninstall printer driver from library folder.
Go to system preferences and delete driver from Library /Printer .
Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 20, 2010 | Computers & Internet
49.4c02 problem.
A 49 error is a corrupt print job. Delete your pending print job then reboot the printer. OR unplug the network cable, reboot printer, it will say Ready. Do not plug in network cable otherwise you will get 49 error. Plug in USB cable, download Firmware upgrade from HP.COM, then plug network cable back in and watch as the previously corrupted print jobs translate fine and print print print ;)
Dec 09, 2009 | HP LaserJet P3005n Printer
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Sep 07, 2009 | Sharp MX-2300N Color Copier
Printer Not Woking In Network
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Jul 03, 2009 | HP LaserJet 1022 Printer
My shared printer will only print a test page and nothing else!
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
One time un reinstall the all printer drivers Before u go to C:\WINDOWS\system32\spool\drivers\w32x86.then delete all folders and files
Apr 08, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 1022n Printer Logo
129 people viewed this question
Seeker5211
Seeker5211
