Question about Shimano XT M772 Shadow 9-Speed Rear Derailleur
Gears change perfectly but notchy feeling when
Gears change perfectly but notchy feeling when pressure appied to lower gears
Don't ever spray wd40 on a bike!
Posted on May 19, 2010
  • jeaster1983 May 19, 2010
    There's a lot of things that could be wrong. Such as your derailleur allignment, chain stretch, cable tension not right. Check all those things.
    Problem Solver:
  • 11 Answers
Spray wd40 in the gear r
Posted on Sep 09, 2009
Steering wheel slips/feel notchy
Has belt been inspected, tension checked?
Mar 04, 2014 | 2011 Cadillac CTS-V
Low pressure on transmission/not enough to shift past 1st-checked fluid in rear differential(2plugs-1-upper+2nd lower for flushing/replacing fluid)very low and appears to have a creamy fluid/water paste...
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward
and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
Feb 26, 2018 | 1997 Audi A6
Transmission
Sounds like this car was submerged in water sometime in its life.
What is your specific question ?
May 04, 2017 | 1997 Audi A6
I have a polo 1.9 tdi the gears on it is a bit
when a vw gearbox is shot it jumps out of gear or grinds badly or even whines out loud,so if you not getting any of the above,...... yes it is a notchy box (skoda make it)
May 10, 2010 | 2001 Volkswagen Jetta TDI
2000 A4: notchy gear change when the engine is hot
Check the gearbox oil - has this been changed (with the wrong grade) just before the problem started ? May also be too little oil, from a small leak - which will get very thin when then inevitably overheating. Best to change the gearbox oil, note if lots of sludge or debris comes out (or is attached to the drain plug). If oil is the problem, total siezure may be just down the road.
Sep 07, 2009 | 1997 Audi A4
84 750ef notchy gears
change your oil,making sure its the correct type. wet clutches use special oil. change the oil filter also.
Jun 19, 2009 | 1984 Suzuki GSX 750 EF
My table saw will turn on, but sounds very loud
Possibly bearing wear, or the blade rubbing against the guard/housing. Unplug the saw and spin the blade slowly by hand, if it feels notchy then I would suggest bearing wear. if it only seems to feel notchy in places then it could also be damaged gears.
Oct 24, 2008 | Saws
Hi, I have a 1991 Suzuki JLX Vitara with the Front Right hub is locked into 4WD and I can seem to unlock it and the gearbox of late feels notchy, sometimes difficult to change into gear
Try hammering the front right hub with a wood or a rubber hammer while slowly reversing the vehicle, and keep on unlocking the hub while doing this.
spray it with lubrication first
yes, you need to change the gear oil in your gear box
Have your clutch re adjusted, it may be worn out , that's why you are having a hard time changing gears or have it bleed to keep the air out if you are using hydraulic.
If you dont hear any noise in your gear box while driving, its nothing serious, worst thing could be replacing your clutch lining and pressure plate.
Oct 07, 2008 | 2000 Suzuki Vitara
Shimano XT M772 Shadow 9-Speed Rear Derailleur Logo
195 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
