Question about Dishwashers
I have a whirlpool quiet wash dishwasher model no. DUG12PF6B2
I followed the advice about taking the inside panel off to get to the control panel. I am not finding a fuse. HELP
The washer is not getting any power to it.
Thanks!!
  • 53 Answers
The fuse is a white square shaped fuse located on the bracket that holds the control board in place, with two wires going to it. When you replace the fuse get the kit that has wire extensions with it. Extend the wires as the kit suggest. It will save you from replacing the fuse again. Current is what took the fuse out.
Posted on Sep 10, 2009
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool quiet partner i dishwasher (model DU1055XTSQ2) that has suddenly stopped working. Control panel has partial functionality. All of the buttons on the control panel have a green LED...
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Thanks!
Nov 14, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Tool to take off panel
Which panel? Why? Most of these screws are either Philips or 1/4 inch head units. Remember to turn off the power.
May 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
Owen Barnes
