Question about Dell Inspiron E1705 Notebook
E1705 Monitor is black also, but can see this screen fine on tv
My e1705 monitor went out today, I can see this screen fine with S-video cable to my TV as I'm using it to enter this. The screen of the laptop actually comes on for a brief second when bouncing back and forth with the Fn and F8 key, but will not remain. on. I also notice that my Wi Fi light is on, have never paid any attention to that before. Any suggestions for a fix is appreciated. Thanks in advance.
  • Dell Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 09, 2009
I have a dell e1705,and it has a white screen what is wrong?
You could have a loose video cable connection that attaches to the motherboard or you may have a faulty on-board video.
Try connecting an external monitor to your Dell, power up the external monitor fist and then boot up the Dell laptop. The video will automatically divert to the external monitor if the on-board video is OK.
This means the video cable/connector needs re-seating or the video cable is faulty.
Mar 07, 2013 | Dell Computers & Internet
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
I was playing solitaire on our home PC and the power went off and the screen went black. Before it went black it said "no input signal go to power save" Everytime I try to turn the computer on...
It means that your monitor is not getting a signal from your PC. Your monitor is fine though. You will need to plug the video cable from your monitor into the onboard video if you are using a graphics card. If you are not using a graphics card then you will probebly need to get a PC technition to diagnose the problem with your motherboard.
Feb 21, 2011 | Vision Computer (2U-A2200K) (2UA2200K)...
I've had my monitor for years with no problems. Today, when I turned on my computer, the monitor flickered. Then the screen went black, and the power button began blinking (green). When I turned it off...
A couple of things to check. First make sure that all the connections are in place. That is, the one at the PC and the one on the back of the monitor. Second - Make sure that the video card is seated correctly in the PC. Third - Replace the monitor cable. Fourth - Check with another monitor, if possible.
Mar 27, 2010 | Dell E153FP 15" LCD Monitor
Power saver problems
Did it come out of power-save mode when you connected it to the other computer?
Does your laptop have a "toggle":
* video-output only to internal LCD screen
* video-output only to external monitor
* video-output to both displays
If so, toggle the setting to "external" or to "both".
Dec 14, 2009 | LG W2252TQ Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Dell Inspiron E1705 does not show any picture
First of all, check that the laptop is set to output video to the LCD. There should be a function key which will determine whether it is outputting video to the built-in LCD, the external monitor, or both. That should be holding down your "FN" key and hitting "F8." If it is on CRT ONLY, it should switch within 1-2 keypresses.
Secondly, take a good bright flashlight and shine it directly at the LCD panel from about 1-2 inches away. If you can actually see the graphics on the screen faintly in the background, your backlight is not turning on. The backlight is literally a bulb which lights up the screen, and they can burn out. It is repairable, and shouldn't cost more than $150.00 from a reputable repair shop.
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Feb 10, 2009 | Philips 52 In. LCD HDTV
Dell Inspiron E1705 Notebook Logo
241 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
