Question about Whirlpool ED5GTNXMQ Side by Side Refrigerator
The refrigerator started smoking this morning and now it smells like burnt plastic. The smell is coming from the bottom and the back of the fridge.
  • basebl17 Sep 09, 2009
    It is a Whirlpool model number ED5GTNXMQ00. It has also been clicking all day long. Not sure if that is the same thing. Could the compressor be bad as well? Thanks
  • Whirlpool Master
  • 1,606 Answers
Sounds like the overload/relay kit , has burnt . This piece is plugged onto the compressor , with 2 or 3 wires going to it . Can be easily replaced . Without model number , can't give you the part number . Take the model number with you , when you go to get the part .
Posted on Sep 09, 2009
Testimonial: "great help "
  • Mike Smith
    Mike Smith Sep 09, 2009
    Very unlikely compressor is defective as well . The overload/relay which comes on the your compressor , is a common part to go out . The pt # 8201786 . This kit (with instructions ) is better than the original part . This part will "short" first , saving the compressor .
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
My refrigerator started smelling like burning electrical wires, it was clicking, then this smoke started coming out the back bottom of the refrigerator. What happened?
it sounds like the motor or electrical conections have burnt out, does it still turn on or has it stopped working completely?
Jan 30, 2012 | Kenmore Refrigerators
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Jul 23, 2010 | Liebherr KIKNV3056 Bottom Freezer...
Clicking noise and fridge/freezer not cold
Hello, This problem is going to be as you suspected the relay. This part is fairly cheap around $30 if you are going to do the fix yourself. The relay is mounted to the side of the compressor. I would change both the overload and relay because of the burning smell you had. If you have an appliance tech in to look at it I would say it's going to cost some where in the region of $150-$200. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Mike
Sep 09, 2009 | Refrigerators
Smelt burning smell in the morning stopped cooling
I suspect the start relay burnt on the compressor. Now the compressor can not turn on. You need to repalce the relay.
Sep 04, 2009 | Kenmore 53542 / 53544 Side by Side...
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Acrid smoke emanating from the refrigerator
Check and see if the smell is coming from the bottom back of the frig by the compressor, this models start device on the compressor has been known too do that.
Mar 19, 2009 | Whirlpool ED2FHEXMS Side by Side...
Potent smell from fridge when turned off...
refrigerant gas can be harmful in high concentration but a regular home refrig does not have enough refrigerant to be dangerous unless directly inhaled at the leak ( it would disipate faster than it ould build up) plus refrigerant is odorless and colorless so you probably wouldnt even know if it was leaking.
Your odor is most likely from a missed food item still in the frig or something that altho cleaned up left an odor behind. the most common culprit is citrus fruits. when they go bad they will leave a gaseous smell behind.
thanks for using FixYa hope that answers your question. Peyton
Feb 19, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirlpool ED5GTNXMQ Side by Side Refrigerator Logo
1,746 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
